Page 2 of 2 1 2
CEG road warrior
CEG road warrior
Motorcraft AZFS22C
Originally posted by SleeperZ:
Originally posted by Wijn:
So "cold copper plugs"...any spark plug names and numbers you want to throw out there?
Wijn
NGK TR6 stock #4177 is what I have always used.
That's the same plug a Duratec uses but the Motorcraft and Autolite lines show a different plug?
The Z in AZFS means "long travel" (~1") and the Duratec uses "short travel" plugs. That means the TR6 is ~.3" shorter in extension compared to the stock Zetec plug.
I wouldn't think the TR6 plugs would reach fully into the chamber???
Does the Zetec plug normally entend a great deal into the chamber?
If that is the fact then the shorter plug would make sense for any boosted application.
I use the NGK's as well...
Brian 2004 Nissan 350z Touring brian8064@hotmail.com
W
Wijn Offline OP
W
Thanks for the input. Heading to the Auto parts store to inquire if they have them. Are they colder plugs???
Thanks
Wijn
1998 tour Zetec B&G springs cut 1" 17" Amp "tech-9" rims Pro tint 2 1/4" exhaust Autometer tach & Euro Guages CTA/weapon R combo intake Zex Dry Nitrous kit
The TR6 is about 5mm shorter than the stock autolite/motorcraft.
But works very well and is one heat range colder than the stock Zetec plug.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST Pre98 Zetec - Some Mods
You don't want to use a shorter plug than stock on the Zetec. It's said if you use a shorter plug the cylider might not seal properly and it would be bad in the long run. I used to run a shorter plug then found out it was shorter and switched to the Motorcraft AZFS22Cs. They are the only plug I've found over the counter that fit perfectly. Copper and one step colder is perfect for a 50shot.
2000 Rio Red I4 Cougar 200whp & 210wtq at 9psi 254whp & 276wtq with NX 35shot WRX TD04 Turbo, Cut Short Shifter, Strut Tower Bar, 17" ZN Wheels, Roush Springs, Starion Intercooler, NX 35 shot, HKS SS BOV, Full 3" exhaust,StreetFlight Chip
W
Wijn Offline OP
W
What did you gap your plugs at??? I just installed the AZFS-22C plugs and gapped them at 45
Wijn
It depends on your setup and how good your ignition is. Without the nitrous you should be able to run stock gap, but under the juice it depends on how big a shot you run. For a 50shot, that sounds good for the time being til you can test it out. If you get a misfire then gap it to .40, but if you have to gap it more then that you should look into upgrading your ignition somehow. Maybe just new wires to start, especially if your current ones are getting on the miles. Ford Racing wires are a good buy.
Page 2 of 2 1 2
