Page 2 of 2 1 2
#112147 01/10/02 09:42 PM
F
F
mine were rusted also... I used wd-40 and left it on there for about 30 minutes...then they came out. Sprayed the hell out of them..
Eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's*
B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers.
Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
#112148 01/10/02 09:50 PM
F
F
Prices depend on where you live. Places in my area are $90/hr for any work. I paid $95 at a friends shop after wasting 3hrs of my time attempting to get the bolts loose. I broke 3 of the manifold bolts but the 4th one I just couldn't get.
Car with 20K miles ended up having a seized nut which stripped the entire bolt. Had to put another manifold bolt in. I consider myslef lucky that all I was charged was $95.
#112149 01/10/02 10:20 PM
I
I
Thats way too much. I was quoted $220 for a high flow cat & resonator installed. If I bring them the y-pipe & resonator they would do the install for $50.00
98 svt #3967/6535
BOD 10/13/97
itg air filter
air inlet pipe
south country strut tower brace
A pillar gauge pod w/autometer Volts, Oil Pressure. and A/F Ratio
Replaced resonator w/Dynomax Bullet
#112150 01/11/02 02:59 AM
You could do like I did on the Borla. A local indep. exhaust shop charged me $20 to remove and replace the bolts on the cat flange. I then removed the new hardware to install the Borla.
So if I go Y-Pipe, I'll probably have them do that again. It took longer to drive there than it did for them to do the work that morning. And I live about 10 blocks from there! laugh
TB
Tony Boner
#112151 01/11/02 08:45 AM
H
H
crap on a crutch! $240? geez, thats insane.. i only paid 200 for my y-pipe hee hee and i put it on myself.
#112152 01/11/02 04:09 PM
thank you for the input. i thought $240 was kind of steep. this was a quote from a performance shop that works on fords. i figured they would do the best work. i am going to find a local muffler shop and try to get it done for 50 or less. you guys just saved me almost 200. thanks again.
Clay
"The Punch"
99 Torreador SVT
1393 of 2760
KKM True Rev
SHO Y-pipe w/cat, NoRes
PIAA 510 fogs w/parking
RoyalPurple Synthetic
In my living room:
SHO UDP
"Because sometimes when I look at my car from the back... It looks like a PUUUNCH"
Page 2 of 2 1 2
