Posts: 2,483 |
I think Buckshot is still doing it.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
Posts: 5,143 |
Originally posted by Wijn: Who optimizes the throttle body??? I'm interested.
Wijn
Yeah, and how much does it cost?
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 5,621 |
Originally posted by ALIAS Jerk: Yeah, and how much does it cost?
Pre- '98 Zetec throttle body, optimized. (NOTE: pre- '98's are more expensive because they have more material to remove than the post- '98's do.)
$80 shipped ($80 Refundable Core charge)
Posts: 650 |
Originally posted by SleeperZ: The mount points, engine mounts, trans mounts, brackets, and frame rails are all different.
I'm wanting to know how different they are..... does anyone know, asap?
97 Zetec MTX Sport
Mk1 Mondeo Morettes & Clear corners
Full SVT kit w/ Molded Mirko Splitter, Carbon Fibre Hood
Ground Control coilovers w/ Koni adjustables, BAT anti roll bar
Pics of my rides in my profile!
Rally drivers do it sideways......
Posts: 2,483 |
Some of the engine mount points are a little different, nothing a custom mount couldn't solve. The oil pan on the SVT Zetec will not fit in the oil pan area of the Contour, so the Contour oil pan would need to be made to fit. The trans is nothing similiar and will require ALOT of modding to fit and mount.
The price/HP ratio is crap. Get an intake ,exhaust, header, cams, udp, and then a tuned chip and you'll be putting out as much HP and more TQ for less money.
Posts: 5,143 |
Originally posted by SleeperZ: Some of the engine mount points are a little different, nothing a custom mount couldn't solve.
I would think the trannie wouldnt fit, itsnt it a Getrag transmission? The same kind they use in the mini cooper?
Would a post 97 throttle body fit onto a Pre98 intake manifold? because I dont plan to have my car out of commission for a week. So I would plan to buy a throttle body out of a junk yard and send it to be optimised.
TEIN H.Tech Springs
Posts: 6,910 |
Originally posted by ALIAS Jerk: Would a post 97 throttle body fit onto a Pre98 intake manifold? because I dont plan to have my car out of commission for a week. So I would plan to buy a throttle body out of a junk yard and send it to be optimised.
I am not sure but I think with tthe core deposit you are sent a tb that is optimized and then you are suppose to send yours back after you switch them, that way you have no down time and Buckshot doesn't have to buy new or get used tb's all the time
- 95 Mystique LS - Zetec/5spd
Posts: 495 |
I think the Focus SVT head will bolt on to our blocks. That might allow a "hybrid" setup, having a SVTF head with a base Zetec block. It wouldn't be as good as the Ford Racing head, but it would be way cheaper and would be a good value for the money if you can find one at a salvage yard used.
The biggest problem then would be the intake VCT, but I think it's just the same as our exhaust VCT so it might be possible to work it with just swapping the wiring for our setups if you have the VCT zetec. Otherwise you could just get the standard exhaust cam VCT eliminator and use it on the intake instead.
If you could find a used SVTF head for a few hundred, plus another 4-500 for a racing header, then you could get an easy 145whp for under $1k. Theoretically.
2000 Rio Red I4 Cougar
200whp & 210wtq at 9psi
254whp & 276wtq with NX 35shot
WRX TD04 Turbo, Cut Short Shifter, Strut Tower Bar, 17" ZN Wheels, Roush Springs, Starion Intercooler, NX 35 shot, HKS SS BOV, Full 3" exhaust,StreetFlight Chip
CEG road warrior
CEG road warrior
Posts: 17,248 |
It will.....my TB is off a 97 ATX.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 5,621 |
Originally posted by brapple: [I am not sure but I think with tthe core deposit you are sent a tb that is optimized and then you are suppose to send yours back after you switch them, that way you have no down time and Buckshot doesn't have to buy new or get used tb's all the time
True.
