I did the following to my 1999 Ford Contour V6 ATX:
1.) Drain ATX (from what I read this is about 4 quarts of fluid)
2.) Add 4 quarts of new fluid.
3.) Drive around (about 20 miles to warm up tranny.)
4.) Drain ATX again.
5.) Add 3.5 quarts.
My question: My fluid level appears slightly high - about a 1/2" above the top of the hot range on the dipstick. I can't figure out how this happened if indeed draining the ATX removes 4 quarts of fluid and I only added 3.5 quarts. In fact, I only added 3.5 quarts because I thought for sure I'd need to add a little. Thought I could do it incrementally. The other kicker is that I was probably already down on fluid slightly just because I recently had a leak (servo seal) which was replaced.
OK, if you replace the servo seal, do you lose a bunch of tranny fluid? Reason I ask is I wonder if AAMCO added too much fluid back to the trans after they replaced the servo seal.
ANy thougths/advice?
'99 Contour SE V6 ATX (stock) '01 Mustang GT (Deltaflows, Steeda Sport Springs, K&N, Accufab 70mm TB & Plenum, MM SFCs, Raptor Shift Light, FRPP 4.10s, Nitto 275 DRs, MRT catted H-Pipe, Steeda UDPs, Steeda Shifter) 13.82 / 101 mph 1/4 mi
Are you keeping the car on and in P when checking the level? When I do the fill and drain, I initially put 3.5qts, then it get it off the ramps. I then keep it on and add as needed.
99 Black Contour SE Sport
H
H
There is no guarantee that you drained 4 quarts...... Seems obvious to me that you drained less than that the first drain......
I'm following the exact procedures detailed in the Haynes Manual, Ford's manual, and on this website (they are all identical.)
The only thing I can come up with is that you really don't actually drain 4 quarts when you drain the trans even though common knowledge says it is.
H
H
Also dont forget you must put the lever in each gear for like 5 seconds to fill the valve bodies. When I had the whole flush done at Valvoline they had me go through each gear like 3 times ending in Park each time.
