#1119521 12/02/04 01:54 AM
How can i get rid of that rattling like pinging noise? Its like a spark knock. I've tried higher octane and a new air filter. Any suggestions?
1999 Contour SE Sport 39,xxx Miles 20% tint, Yokohama AVS tires 205/60/15 Aiwa cd player 1988 Ford F-150 4x4 31/10.50/15 mudders 2 10" Subs, Clarion Cd Roll pan, bed cover, black outs all 4 corners 5% tint,Dual flowmaster's, K&N filter
#1119522 12/02/04 02:06 AM
H
H
When does it happen first off?
I know pinging on acceleration is due to a really lean mixture I'm told.
#1119523 12/02/04 06:54 AM
Pinging happens at light to moderate load.
Pinging is usually due to a lack of EGR, but can also be caused by carbon buildup in the cylinders.
If you put in 93-94 octane and it dit not get any quieter, it may not be pinging.
#1119524 12/02/04 03:53 PM
I have had this problem also, I can hear mine when the car is in idle, ie startup. I don't konw if I can hear it anywhere else because I haven't gotten out at a stop sign to listen :-p. I have also put in the "high" octance and it made not a difference. I had asked my dad about it, because I thought maybe it was a spark plug that was not firing completely. The car accelerates with no problem though. I have poor gas mileage as well. I"m thinking it may be the EGR vavle itself, but no engine light.
#1119525 12/02/04 08:55 PM
I have pinging under heavy load, such as going up a hill. Mom's Taurus has pinging also. Main problem is too much heat in the combustion chambers. She has a Vulcan, and not a Duratec however. Try cleaning your motor out and get those temperatures down. Try a different gas station. My car pings bad with Exxon. In fact, I hate Exxon, but that's another story. Valero is the best (Diamon Shamrock) followed by Amoco.
2000 Contour SE
#1119526 12/03/04 12:01 AM
A loud rattle at startup is the timing chain.
A slight rattle at idle is the valves.
A knock can be rod bearings or crossfiring plug wires.
Ping is only under acceleration.
