#111786 01/04/02 03:02 AM
I just tried to optimize my TB on a 2000 SVT. I was following the instructions given by Scott Burton (July 2001). THe thing is he mentioned that butterfly was mounted to a half-circle on the throttle shaft. My shaft is a full cirle with a slot in it for the butterfly. So I rounded off the screws and polished everything. So does anybody else have this TB shaft and what did you do? Cut half the round off to make a flat surface?
2000 Black SVT
SHO y-pipe / hi-flow cat
Large Cone Filter
B&M shifter
C&L 73 MAF
Pro-Flow Optimizer
Magnaflow Res
BAT Intake
Always looking forward to beating those coffee can wanna-be-fast imports.
Douchebag Racing: You dont need a racing team and trailer for a 14 sec. car.
Check it out: www.geocities.com/jcs9614
#111787 01/04/02 07:20 AM
That's the standard TB design.
I just filed down both upper and lower parts of the rod until it was just over the scary thin stage. laugh
Countersunk the upper and added countersunk screws. (loc-tited & peened)
Knife edged the plate and the TB outter lip
Smoothed the inner lip
Polished everything smooth...
2000 SVT #674 - Check it out!
#111788 01/04/02 04:04 PM
I cut the front portion of the bar off on the ones I do.
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
#111789 01/04/02 06:10 PM
Brad,
Do you still perform these? If so where can I find out more info on it?(like price..etc) Do you offer core replacements so it will be easier.
I'm very interested in getting this done...I have been wanting to do it myself for quite a while but I'm afraid I just don't have the work space, time, or tools to do it. smile I live in an Apt!
Thanks
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
#111790 01/04/02 06:44 PM
Originally posted by jcboeckl:
Brad,
Thanks
I have it listed as an option on my powdercoating page because I don't really want to do a whole lot of them, but as an addition to powder coating it makes sense because I have to take them apart anyway. I can get cores if anyone expresses a paying need for one, also available on my powder coating page. wink
Brad Noon
'99 SE MTX
#111791 01/04/02 07:07 PM
Ok...I checked out your website! $35 seems very reasonable for the optimization....And the $100 would be refunded as soon as you recieve my TB!
Also can you give a run down on what you actually will do to the TB? I know some ppl do it differently.
Thanks
Justin
1998 Black SVT
#111792 01/04/02 07:47 PM
Brad did my TB and I can tell you he does good work. wink
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
#111793 01/04/02 08:51 PM
Well, $35 in addition to doing the coating service since I'll have it apart in the first place. If someone wants to do a TB optimization by itself, I'll have to charge more. I guess I could do it for $50 by itself... I just don't want to do it on a large scale again like I did before... I had 5 in one week = to much for spare time to handle... Understand?
What is accomplished:
Throttle bar halved
New screws countersunk into front side of throttle plate
Rear of screws filed off flush (held in place by JB Weld)
Throttle plate thinned and knife edged (knife edged new)
Front bore lip opening knife edged
Throttle plate bore machine surface blended
Any casting flash removed
Cotton wheel polished inside bore(new)
Brad Noon
'99 SE MTX
#111794 01/04/02 11:58 PM
Ok well that still sounds cool!
About the Ford Blue color of your powdercoating, would it somewhat match the blue hoses the BAT pipe comes with?
Also I'll probably want to do this in about a week, so I'll shoot you an email about the specifics.
Would you be interested in doing one for me? I understand you have alot on your plate and I wouldn't expect it to be done asap, just whenever especially since I will be doing the core replacement.
Just let me know smile
Justin
1998 Black SVT
#111795 01/05/02 12:54 AM
I would also be interested in an optimization and powerder coating.
So it would initially cost $185, then once you get my core back you refund the $100. Correct?
I will be sending an email shortly as well.
2000 Black SVT
Large Cone Filter
B&M shifter
C&L 73 MAF
Pro-Flow Optimizer
Magnaflow Res
BAT Intake
