Page 8 of 8 1 2 3 4 5 6 7 8
#1117718 12/13/04 09:13 PM
Well if you saw all those posts I'm guessing you searched. And under that search Stazi's post would have turned up.
From this post.
Well last night I went ahead and installed the fitting for my Oil Pressure gauge into my block.
The right place to get it is at the main Oil gallery feeding the crank!
The other spot high up on the head doesn't give you a true reading as it is after a restrictor plate.
the correct place to tap in is behind the A/C compressor on the Duratec.
3 bolts loosens the A/C compressor, and with the belt off, and also unscrewing the A/C line that's joined to the front crossover coolant pipe you can move the A/C compressor forward towards the radiator enough to see a plug to the left of the oil filter connection and a little under the stock oil pressure sender.
You need to use an 8mm Allen wrench to remove the plug, then install a female/female reducer and then a 90? elbow followed by the reducer you get with the Mechanical Oil Pressure Gauge kit and then finally the compression fitting.
#1117719 12/13/04 09:17 PM
RawBurt Offline OP
Thanks Todd, that actually was really helpful!
#1117720 12/13/04 10:18 PM
Y
Y
Now go strip some A/C Compressor bolts, bust some knuckles, and come back to tell us about it
Good luck!
Mark
#1117721 12/15/04 05:17 AM
Captain Impound Boy
Captain Impound Boy
Originally posted by WRX Barge:
For future reference for anyone else don't get the lotek gauges painted from lotek because they never match. Just buy it plain black and then paint it with actual ford interior paint.
Mine matches! soo shut it tweece!
#1117722 12/15/04 05:19 AM
Captain Impound Boy
Captain Impound Boy
some people like for your to hold there hand.. Rawburt seems to be one of them people. I know its tough to search.
#1117723 12/15/04 01:13 PM
RawBurt Offline OP
Then why dont you just hold my hand *JOKING* and then install them for me. I Did Search and found lots of helpful information. But i severely lack in this category and that's why i am asking for extensive help.
#1117724 12/15/04 02:03 PM
Y
Y
Extensive help in your case should come in the form of somebody else doing the work and you paying for it.
Mark
#1117725 12/15/04 02:11 PM
RawBurt Offline OP
Mark
That would be too easy though! That's why i am going to figure it out myself and learn something new.
Hey if i can hook up volts i can hook up anything right!!! [Sarcasm]
Well this looks like all the help i will be getting or needing so let this thread end!
