Page 5 of 8 1 2 3 4 5 6 7 8
#1114032 12/17/04 09:08 PM
If your going to run that high of a comp ration and can get some wild cams, than you will need those cams specs before ordering. Possible even a block to measure piston to valve as that high if a comp plus cams will have some wild valve relives and dome design. But again thats if you have wild cams.
'99 Silver svt For sale 19" Axis Neo wheels 3.0 parts, pre-98 trunk, Check classifieds bp.powell@comcast.net
#1114033 12/18/04 01:27 AM
How much are rings?? WHat is the price with the 5 people...maybe I can pull some money out my a$$
98 E0 SVT with some stuff
#1114034 12/18/04 04:29 PM
Numbers I came up with were going from 10:1-12:1 will only net about a 4.7% increase, and like others pointed out that may not be optimal for gains opposed to running 10:1 and more timing
I found this to be a decent read.
Personally I'm taking the money I was going to drop on pistons and the other parts needed to install them and I'm goning to drop it on a nice set of TCE brakes in the spring since I have a nasty habit of melting my brake piston seals on the track.
Then: 99 Silver Frost SVT #1919 237hp/219tq All Motor Now: 06 White STI Parts 4 sale
#1114035 12/24/04 07:14 PM
I talked to my contact at Diamond and he agreed to do the buy with only 4 sets if I can get them.
This is a list of info that I need to fill out for him. I misplaced all the info I had and currently don't have time to search for it. So if someone (Demon ) would be kind enough to email it to me it would be appreciated.
# of Cyl. = 6
Bore 2.5/3.0 = 3.25/3.5
Stroke = 3.xx
Rod Len. = 5.433 center to center
Gskt Bore
Comp. Gskt
Block Deck Ht.
Top ring down
Chamb. Vol. = 46cc?
Dome (-) Dish (+)
Piston / deck
2001 Lincoln LS8 1994 Lexus GS300
#1114036 12/24/04 07:45 PM
So what is the rpice for the 4 sets? And any idea on rings yet?
#1114037 12/24/04 08:04 PM
N
N
I hope I can pay for the pistons now and give Diamond the particulars on them after the first of the year. I need to find out what the head volume will be after porting and polishing and Jesse (kinger) just sent me a message saying he will be off line until the 2nd of January.
The Original Owner of 1998 SVT Contour #3384 of 6535, Toreador Red/Midnight Blue, Assembled September 3rd, 1997 Also the Original Owner of a 1998.5 Contour SE Sport V6 5-speed, Vibrant White/Greystone Sport Cloth, Assembled August 6th, 1998
#1114038 12/24/04 08:19 PM
Price will stay the same as 5 sets. Rings will be somewhere between $75 and $130 depending on if they are a shelf item or have to be cut. Being that all so far have a different idea of what they want it's hard to look up part numbers.
#1114039 12/24/04 10:28 PM
prettty much I need you to tell me want I want...9:1, 3L, with 3L oval heads...no porting of the chamber. stock rods, stock bore, and stock stroke...although, with rings and the 646...it seems I may just have to wait...I have scraped up almost all I can...we'll see.
#1114040 12/24/04 11:46 PM
$626 + rings. That includes the 3% increase for the new year.
#1114041 12/25/04 04:58 PM
hmm...is there anyway we can still get this done this year? If I pay next week, does that make 4 or matter?
Moderated by  1314_dup1
