Posts: 1,860 |
Well the price goes up in 05 so I would say by the end of the month.
I think the Ross piston deal had to have the skirt shaved or something. I'm not quite sure.
2001 Lincoln LS8
1994 Lexus GS300
Posts: 1,101 |
Originally posted by Keyser: Well the price goes up in 05 so I would say by the end of the month.
Let me do some creative financing and I'll get back to you asap.
Posts: 1,859 |
Originally posted by stilov: Chris let me see what I can do. Tell me though, what is this "modification" to ross pistons that must be done? What is the deadline on this group buy anyway?
Theres no modification to Ross pistons, at least not anymore. I beleive that was just the first set.
'99 Silver svt
For sale
19" Axis Neo wheels
3.0 parts, pre-98 trunk,
Check classifieds
bp.powell@comcast.net
Posts: 225 |
It is already the 9th; is this thing going to happen?
The Original Owner of 1998 SVT Contour #3384 of 6535,
Toreador Red/Midnight Blue, Assembled September 3rd, 1997
Also the Original Owner of a 1998.5 Contour SE Sport V6 5-speed,
Vibrant White/Greystone Sport Cloth, Assembled August 6th, 1998
Posts: 1,336 |
Add me to the list!
3.0L 1mm overbore 9.5:1 CR
Posts: 1,860 |
Originally posted by Keyser: Ok here we go:
1.Eternal One 3L 9.5:1 2.NVSVT 2.5L 10.5:1 3.FastCougar 9.5:1 .040 over 4. 5.
Just to let you guys know I was informed of an increase in price after the new year.
Also NVSVT if you can get your car to Phoenix there is almost nothing we can't do to your contour(s). It's only about 5 hours from Vegas.
2001 Lincoln LS8
1994 Lexus GS300
Posts: 1,336 |
Make that .5mm overbore ... I was looking at the wrong information
Posts: 2,676 |
guys these are worth it
mine have worked well in Houston summers at 16psi, no problems. . .no piston slap, nothing. . .I originally got these pistons because the GB needed one extra person, had no plans of turbo charging, but lemme tell ya, well worth it. . .
Posts: 279 |
Pretend you are trying to explain this to a Grade 8 student taking shop class:
1. What are the advantages of these pistons & 2. What is the re/re labour involved?
thanks
Dan
2000 Black SVT #2639/2760; w/18 OZ Superleggera's, Pirelli Pzero Nero.
MSDS Headers,Quaife LSD, CF DF, Borla,,chipped,DMD,Baer Track rotors.
Lowered/HR and Koni's; HPP & OMP
3L Valves w/ P&P Heads (thanks Kinger!)
Posts: 3,732 |
1. What are the advantages of these pistons for forced induction, they are much stronger than stock and can handle alot more boost. even for nitrous they can handle alot more than stock. not to mention you can lower compression for a turbo or supercharger, or raise it for n/a or nitrous 2. What is the re/re labour involved? removing the engine would be the easiest way by far. gotta take the timing chains off, cams out, heads off, then take the rods and pistons out. install new pistons to rod, and put rod/piston back in car. new rod bearings needed along with new rod bolts and new head bolts. basically very expensive
Russell
Oval Port 3L Nearly Done
