Page 3 of 8 1 2 3 4 5 6 7 8
#1114012 12/05/04 10:40 PM
Well the price goes up in 05 so I would say by the end of the month.
I think the Ross piston deal had to have the skirt shaved or something. I'm not quite sure.
2001 Lincoln LS8 1994 Lexus GS300
#1114013 12/06/04 12:12 AM
Let me do some creative financing and I'll get back to you asap.
Then: 99 Silver Frost SVT #1919 237hp/219tq All Motor Now: 06 White STI Parts 4 sale
#1114014 12/06/04 03:05 AM
Originally posted by stilov:
Chris let me see what I can do. Tell me though, what is this "modification" to ross pistons that must be done? What is the deadline on this group buy anyway?
Theres no modification to Ross pistons, at least not anymore. I beleive that was just the first set.
'99 Silver svt For sale 19" Axis Neo wheels 3.0 parts, pre-98 trunk, Check classifieds bp.powell@comcast.net
#1114015 12/09/04 08:52 AM
N
N
It is already the 9th; is this thing going to happen?
The Original Owner of 1998 SVT Contour #3384 of 6535, Toreador Red/Midnight Blue, Assembled September 3rd, 1997 Also the Original Owner of a 1998.5 Contour SE Sport V6 5-speed, Vibrant White/Greystone Sport Cloth, Assembled August 6th, 1998
#1114016 12/10/04 01:37 PM
F
F
Add me to the list!
3.0L 1mm overbore 9.5:1 CR
#1114017 12/10/04 03:05 PM
Ok here we go:
1.Eternal One 3L 9.5:1
2.NVSVT 2.5L 10.5:1
3.FastCougar 9.5:1 .040 over
4.
5.
Just to let you guys know I was informed of an increase in price after the new year.
Also NVSVT if you can get your car to Phoenix there is almost nothing we can't do to your contour(s). It's only about 5 hours from Vegas.
#1114018 12/10/04 03:59 PM
F
F
Make that .5mm overbore ... I was looking at the wrong information
#1114019 12/10/04 04:41 PM
guys these are worth it
mine have worked well in Houston summers at 16psi, no problems. . .no piston slap, nothing. . .I originally got these pistons because the GB needed one extra person, had no plans of turbo charging, but lemme tell ya, well worth it. . .
#1114020 12/10/04 10:31 PM
Pretend you are trying to explain this to a Grade 8 student taking shop class:
1. What are the advantages of these pistons &
2. What is the re/re labour involved?
thanks
Dan
2000 Black SVT #2639/2760; w/18 OZ Superleggera's, Pirelli Pzero Nero. MSDS Headers,Quaife LSD, CF DF, Borla,,chipped,DMD,Baer Track rotors. Lowered/HR and Koni's; HPP & OMP 3L Valves w/ P&P Heads (thanks Kinger!)
#1114021 12/12/04 09:29 AM
for forced induction, they are much stronger than stock and can handle alot more boost. even for nitrous they can handle alot more than stock. not to mention you can lower compression for a turbo or supercharger, or raise it for n/a or nitrous
removing the engine would be the easiest way by far. gotta take the timing chains off, cams out, heads off, then take the rods and pistons out. install new pistons to rod, and put rod/piston back in car. new rod bearings needed along with new rod bolts and new head bolts. basically very expensive
Russell Oval Port 3L Nearly Done MTX75 w/ Homebrew Zetec FD and Torsen Complete
Moderated by  1314_dup1
