Page 1 of 3 1 2 3
svt4stv Offline OP
i got in on the group buy for H&Rs. then, i see someone posting a pic that they will make the car look raked. i have been thinking over the two before but have not even heard of this nor did i notice this. I tried doing a search of H&Rs but came up with only a few pics, out of the millions of thread results. some of the cars didnt seem raked. i do NOT want my car to look raked. it doesn't look bad its just not for me. apparently, the eibachs will be level? if i decide to go with eibach, there are plenty of people who would gladly take my spot on the H&R GB. it's a great deal!
can people pleeeeaase post pics of csvts that are have eibach or h&r so i can compare them side by side. also, would shocks, stance/looks wise, make a difference at all? please tell what springs, shocks, and size of wheels when posting.
hey, its free-whoring time!
Eibach's with 17 x 7 in. Focus SVT wheels and Continental ContiSport Contact 215/45WR-17 tires, stock SVT Struts (Koni's go on in the Spring)
Eibach's gave me ~1.75" or more drop...NOT 1.2" - 1.3"
Scott
Scott 2000 Contour SVT #1464 Mustang Dyno: 171.6hp/145.3lb Dynojet Dyno: 171.1hp/148.9lb 1989 20th Anniversary Turbo T/A "Indy 500 Pace Car" #1376 of 1550 All Original, 46k with a few mods 2002 F150 SuperCrew
svt4stv Offline OP
that looks nice.
im hoping more people will post. id like to see some profile shots.
lemme get this straight. the H&R's dont drop as much as they are supposed to? and the Eibachs drop way more than theyre supposed to..
my svt w/ H&Rs, 18" adr reactions, yokohama parada spec 2's...
my pre 98 w/ eibachs and same rims and tires as above...
i like the look of the eibachs better. the raked look isnt my thang.
Oo (xxx)oO o xxxxxxxx o
An "optimal" setup for LOOKS only wold be H&Rs up front with Eibachs out back. Other than that, these two springs create two different looks. Steve, you saw my car at the track, I have Eibachs. Did you notice any rear end sag look? At times it's noticeable, but most of the time it's not. Also depends on if you want springs for performance or looks. H&Rs are recommended for performance while Eibachs are more for looks, respectively.
99 SVTC, T-Red, #652/2760-12.8.1998 Mother#@%@!* did I sound abstract? I hope it sounded more confusin than that!
W
W
I had Eibachs with Konis and the car stayed flat in hard turns. It was used for AutoX before I got it so assume the Eibachs do just as well as the H&Rs if not better. I did notice the sag in the back, but it was not so evident unless you were looking for it.
1999 Contour SE Duratec ATX My feet and the Stra�Ÿenbahn http://www.tempo-topaz-performance.com/topazsho/ the coolest Topaz ever! To bad it's not mine
just because it was used in auto-xing before you got it doesn't mean that Eibachs are better than H&Rs....
I
I
H&Rs all the way..
how much does the combination go for?
W
W
Scott
I'm still not gettin this. I have Eibach's and Bilstein's. If I look into the wheelwell, the top of my front tire is exactly 2" below the fender lip. Yours looks much less--what is it? I will end up with H&R's in the front and Eibach's in the rear. My tires are 215/45-17's.
WA 2 TUFF SVT 2000 Tropic Green SVT Born 1/28/2000-1975 out of 2150-only 207 made. Some new pics
Page 1 of 3 1 2 3
