Page 2 of 2 1 2
go to autozone and get a battery.. i have been using them in my 93 taurus for years and had no more peoblems with them than any other brand battery... when i needed a battery for the contour autozone did not carry one for it, but now they do .. go there and check out the price....
bullion Offline OP
Check out the price on what battery?
98' Contour SVT #607 of 6535 05' Mazda 6s Audio/Visual enthusiast because it's one of the many things I went through 4 years of hell for
Originally posted by bullion:
Just for kicks I hooked my voltmeter up to the battery and it read 12.30 volts. Also, all my accessories seem to be working fine (like my heating/cooling and stereo......those all will function right now). Is it still possible I could have a dead battery and all those accessories still work like that?
Are you saying you had 12.30 volts with the car running? Because if you did test it with it running and 12.30 is all your getting...then your battery is not your problem, its your alternator. With the car running and your voltmeter on the battery you should be getting 14.50 volts...and as you turn on accessories it drops slightly but never below about 13.0 volts so as not to discharge when your acc are on. Check it again...this time with car running and tell us what your getting...should be 14.50 volts when running.
bullion Offline OP
No, it is at like 14.2 volts when the car is running. I am pretty sure I just have a bad battery.....
Page 2 of 2 1 2
