Posts: 5,600 |
Originally posted by akrump47: And now you can!
Pic of my mesh installed
Black 1998.5 CSVT
Posts: 1,475 |
Rawburt - yes you will have to cut or dremel the tabs on the front. Per Stazi's suggestion I bent the mesh to the shape of the grille opening and then lined it up with the top middle 2 tabs. I had to trim the mesh on one side afterwards as it curves sightly upwards after assuming the shape of the grille.
It's a very tight fit on the tabs after you get it on, trust me you won't need anything else to hold it in place. Oh and I personally couldnt figure out how to get the stock mesh out without destroying it.
Hey Stazi - is there any point to those deflector-thingys on the sides of the stock mesh?
Posts: 6,791 |
Originally posted by akrump47: Rawburt - yes you will have to cut or dremel the tabs on the front. Per Stazi's suggestion I bent the mesh to the shape of the grille opening and then lined it up with the top middle 2 tabs. I had to trim the mesh on one side afterwards as it curves sightly upwards after assuming the shape of the grille.
A little confused there...
Posts: 10,015 |
They're supposed to deflect the air towards the radiator more, but I've been without them for years and noticed nothing different.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 317 |
Originally posted by carrot_top: got the grill on saturday, however, it was broken. the tabs on the grill broke...but i got the other 2 pieces installed.
Cheers Suriel
One of mine were broken, too. I used JB weld epoxy and a piece of lexan on the underside of the tab to reinforce it. It seems to be actually stronger than the original plastic.
Originally posted by LUCA: Yep.
You can be Phil too if you'd like.
Posts: 710 |
i only received 1 broken tab... the other is MIA. Any suggestions?
morbid
2000 Contour SVT (black)
Posts: 4,051 |
Originally posted by morbid: i only received 1 broken tab... the other is MIA. Any suggestions?
LOL, Same here. I just ignored them. It holds just as good without them, as long as you put the screws back on.
Posts: 10,015 |
There are only 2 tabs, and they're up top. How many could you be missing?
Another option is to make metal tabs from metal strapping, and JB weld those onto the remaining tab.
AUSSIE ENDLINKS $70
