Page 24 of 24 1 2 22 23 24
Originally posted by akrump47:
And now you can!
Pic of my mesh installed
#4559 of 6535 born on Feb 17, 1998 Black 1998.5 CSVT FOR SALE [cleaning house]: SVT rear swaybar. Reasonable offer and its yours!
Rawburt - yes you will have to cut or dremel the tabs on the front. Per Stazi's suggestion I bent the mesh to the shape of the grille opening and then lined it up with the top middle 2 tabs. I had to trim the mesh on one side afterwards as it curves sightly upwards after assuming the shape of the grille.
It's a very tight fit on the tabs after you get it on, trust me you won't need anything else to hold it in place. Oh and I personally couldnt figure out how to get the stock mesh out without destroying it.
Hey Stazi - is there any point to those deflector-thingys on the sides of the stock mesh?
RawBurt Offline OP
A little confused there...
They're supposed to deflect the air towards the radiator more, but I've been without them for years and noticed nothing different.
9
Originally posted by carrot_top:
got the grill on saturday, however, it was broken. the tabs on the grill broke...but i got the other 2 pieces installed.
Cheers
Suriel
One of mine were broken, too. I used JB weld epoxy and a piece of lexan on the underside of the tab to reinforce it. It seems to be actually stronger than the original plastic.
Originally posted by LUCA:
Yep. You can be Phil too if you'd like.
i only received 1 broken tab... the other is MIA. Any suggestions?
morbid 2000 Contour SVT (black)
LOL, Same here. I just ignored them. It holds just as good without them, as long as you put the screws back on.
There are only 2 tabs, and they're up top. How many could you be missing?
Another option is to make metal tabs from metal strapping, and JB weld those onto the remaining tab.
Moderated by  1314_dup1
