Page 5 of 24 1 2 3 4 5 6 7 23 24
RawBurt Offline OP
1. RawBurt
2. carrot_top
3. RedRyder
4.tour96se(front&rear,Contact stazi directly through PM for price)
Guy's I've never done the lower fron on an SE. An I do not have a template to work from, so I won't be doing those. The SVT grills are something I've done a ton of times and I don't feel like screwing around, especiall in the cold, working out how to do the lower fron on a non-SVT.
The ovals are all the same, even though the SE one requires more junk to be removed from the oval itself.
  • If you want just the Oval - $45 installed and shipped.
  • If you want just the Oval and rear (if you have and SVT rear bumper on an SE) - $55 installed and shipped.
  • If you want to install the oval yourself and I just supply the SVT Lower, Rear and piece for the oval - $70 shipped.
  • Canadian orders add $10 to the above prices.
If you screw up a piece and need replacements, you will have to repuschase those pieces again from me.
If you want anything but the standard aluminum colour, paint them with Krylon spray paint for outdoor furniture, etc. It's that easy. I painted mine this way.
RawBurt Offline OP
And for all 3 grills plus the oval installed by Stazi, its $98 correct?
When we send you the oval dont you want us to take out the plastic grill thats already in there?
Don't touch/remove/cut/modify sh!t. Just unbolt the whole oval grill and send it to me. I need both halves of it.
Full kit is $98 - correct.
RawBurt Offline OP
Just out of curiousity why do you need the stock plastic grill that is in the oval?
Y
Y
He doesn't.. It gets junked, but he says to send it all to him so he can take it apart himself, rather than F'ing it all up by hacking into it yourself. Not that I speak from experience
Mark
RawBurt Offline OP
So stazi has a giant pile of them in his garage?!
I need both halves in order to sandwhich the mesh between both pieces, and to do this I need to modify various things. The original plastic mesh gets removed and sent to Garbage City.
RawBurt Offline OP
What if people want the plastic piece returned... is that possible?
Sure but what will you use it for, straining spaghetti?
When it get cut out, it generally doesn't look to pretty and becomes useless.
Moderated by  1314_dup1
