csvt_33 Offline OP
Flashes intermittantly only during acceleration and cornering. I don't feel any grabbing or anything to suggest the park brake is sticking, so I'm assuming its a weak switch thats making during said conditions. Anyone else ever run into this or know where the brake switch is? Thanks
98 E0 #4100 18's n stuff 06 Mazda6s Sport Wagon 89 Thunderbird SC
low fluid
csvt_33 Offline OP
I never thought that light was multi-function. It comes on to indicate parking brake is set only, right?
H
H
No 3 three reasons only, well four.
parking brake set
low fluid in master cylinder
a brake line snapped grounding that thing on the master cylinder, completed circuit and lighted the dash light
of course a serious eletrical problem could cause it as well
csvt_33 Offline OP
idiot now heads to garage to check fluid levels...
H
H
Remember DONT open the master cylinder unless you want to flush the fluid. Brake fluid cant be exposed to air.
csvt_33 Offline OP
Well whaddya' know. Found sensor, found fluid only 'bout 1/4" above min. line. Thanks fellas!!!
Now go figure out WHY the fluid level was low.
Most often it is due to severely worn pads (or shoes). It can also be due to a leak.
Only adding fluid can cause a false sense of security.
Steve
csvt_33 Offline OP
Thanks SHO. Makes sense. I know I'm due for pads n rotors, its been awhile, but stopping power is still so good that it's easy to forget.
