#1110899 11/20/04 03:47 PM
dkawa Offline OP
Hi
My check engine light is on.I had it scanned and the code was p161 O2 Sensor heater circit Malfunction (bank2 Sensor2}.My question is which sensor is it? Which Bank is Which? The code started after i r&r the trans to relpace the 3rd gear syncro.Pleas help
#1110900 11/20/04 04:58 PM
R_G Offline
I would say Bank 2 is the downstream sensor, the one that's after the catalyst. That's if you are driving a 4 banger. Not sure about the Duratecs though.
#1110901 11/20/04 08:04 PM
dkawa,
On a Duratec, Bank 2 is the side closest to the radiator. Sensor 2 is the one downstream of the precat.
#1110902 11/20/04 08:50 PM
N
N
R_G:
Don't say that anymore, becauze on a 4cyl you only have two O2 sensors, the upstream and the downstream. You can't speak about bank on a 4cyl.
Nic.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
#1110903 11/20/04 11:27 PM
BANK BANK BANK BANK BANK BANK BANK BANK
The codes are for bank one or bank two. The Zetec has bank one.
