Posts: 20 |
How do you know what your build date and svt producation number is without the original documentation, is it on a tag somewhere?
Posts: 1,506 |
IIRC, you can call Ford-SVT with your VIN. If Ford SVT still takes calls/still exists.
MSDS, SHO-shop Y, custom 2.5" catback; xcal2; 63mm TB, K&N 3530; Koni struts, Aussie bar; THaines forks, Quaife, SpecII, UR fly; DMD; Nima UD pullies; Stazi brakes; f&r Pole120 mounts. Just a daily commuter car. Silver '98 SVT E0 #3159
Posts: 4,714 |
Originally posted by PDXSVT: IIRC, you can call Ford-SVT with your VIN. If Ford SVT still takes calls/still exists.
SVT exists, and according to the horse's mouth, will continue to exist. Its only 66% of their product line that has been axed.
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 6,791 |
Isn't it 1-800-Ford-SVT that gives you the certificate????
Posts: 230 |
The build date is on the inside on my door...didnt see the production # though. maybe I didnt look hard enough but I too would also like to know what my production # is. Any other way beside calling SVT to get it?
Posts: 1,610 |
Posts: 392 |
If you check in theFAQ in the VIN decoder, shouldn't that suppose to be the 12-17 digits of your VIN? I might be wrong, but...
Nic.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
Posts: 230 |
Originally posted by Nic_ContourSE99: If you check in theFAQ in the VIN decoder, shouldn't that suppose to be the 12-17 digits of your VIN? I might be wrong, but...
Nic.
ummm huh? link?
Posts: 3,788 |
Originally posted by RawBurt: Isn't it 1-800-Ford-SVT that gives you the certificate????
Yep! Call that number, give them your VIN and they can tell you what your build number is. Ask them about getting the certificate with the build info on it. The certificate is free, IIRC.
Posts: 9,872 |
Originally posted by LUCA: Originally posted by RawBurt: Isn't it 1-800-Ford-SVT that gives you the certificate????
you hafta send in your registration and whoa la!!!
