#1109997 11/19/04 02:03 AM
OK Heres the problem. I recently installed my amp and speakers in my CSVT and came across a problem. The amp is a Xtant 404m and the speakers are JL W-3's 12 inch. I ran all the wires and as soon as I hooked up the power wire a small amount of smoke came out...which cant be good.... The amp was already grounded. And since then the red light has been on every time I start the car to see if it works. There are 3 lights, green, orange, red. No other lights come on. The fuse in tghe power wire is fine(30amp). So I decided to take the cover off the amp and found 2 small resistors that looked burned...Numbers R19 and R20 next to them on the board. Can these be fixed?? And am I right on guessing that those are whats causing no amp and red light??? Any help would be great guys!!!
Jonathan
#1109998 11/19/04 04:47 AM
It's called protection mode, and yes you fried your resistors. It can probably be fixed, and the best place for it is http://www.kbaudio.com Sergey is a nice guy, and their prices are reasonable. Plus they'll test it when they are done fixing it and send you a new birthsheet with it.
Regards,
Morgan
1998 Contour GL 2.0L Zetec Stock as hell for the moment....
#1109999 11/19/04 05:12 AM
Thanks....I just went to Xtants website and found out this info...
Red LED=Power on
So I have power to the amp, no protection lights on so will those blown resistors still prevent no sound??
Jonathan
#1110000 11/19/04 05:09 PM
they very well could!
2002 Cougar 2.5 duratec/ mtx-75 85,0000 Mondeo ST-200 wheels/BFG KDW NT black/black Spec Stage 1 Torsen T-2 Trubendz 2.5 flowmaster dual exaust apexi s-afc II K&N FIPK
#1110001 11/19/04 10:59 PM
I have never known a company to use Red to show power, as usually red is bad.... and yes, those resistors can cause the amp to not produce sound....
Moderated by  dnewma04_dup1
