#1109919 11/18/04 11:44 PM
E
E
Im wiring up some fog lights today and i didnt want to use the plug that came with the car (00 se) because it didnt have juice. So i went to autozone and picked up 2 headlight sockets and am going to use those (i bought them and screwed with them before i realized i had them already). But, before i wire it all up, i need to know if fog lights have a polarity? Or do i just hook up positive to one and ground to the other wire? If it does have polarity, how do i tell which is which (im using my own connectors and wire)?
thanks
-ivan c
#1109920 11/19/04 02:10 AM
Yeap polarity it has. Read carefully: http://www.metalreviewcentre.com/Foglight.htm
#1109921 11/19/04 05:23 AM
E
E
Good to know. But how do i know which pin on the bulb is + and which is ground? Should i just hook up a 12v power supply to it and see which way it works (i tried in on a headlight bulb and it turned on either way).
ivan c.
#1109922 11/19/04 09:27 AM
Not sure how your exact application is (and even if I did, I'm not all that great with this stuff), so can't really tell ya. I just added stock foggies to my car and wired them with a relay to battery and use headlights as the switch, pretty simple.
#1109923 11/19/04 06:47 PM
E
E
Thanks for the link kremit. Im using the bat fog lights and bulbs and am running my own wire since i dont want to mess with the original harness (putting a switch on the middle of the cupholder and a fuse near the battery). I went and got a bulb out of the car and wired it up to a 12 power supply and it lit up either way i put it. Would i be safe in assuming that i can wire it up either way then (even after reading the site)?
thanks
#1109924 11/19/04 06:59 PM
I just hooked them up the way the link said to. Here's another link you may find helpful.
http://www.cardomain.com/memberpage/500739/5
#1109925 11/20/04 09:39 PM
E
E
Well i finished wiring up the lights, using the link you gave me, and all is good so far. Ill post some pics in a few days of the switch mount (once i get a new switch since the led burnt out) in the pics forums. Thanks a million kremit!
-ivan
