Posts: 9,872 |
Originally posted by alex_96GL: I am a a strong proponent of replacing suspension parts in pairs though.
yea then i guess I'll do the whole thing then, thanks for being patient with me man
Posts: 9,872 |
by the way, anyone know the part number for the front sway bar links?
Posts: 9,872 |
nvm, I found it all here I guess I need #15 and #13.
Posts: 7,117 |
Posts: 9,872 |
Originally posted by TourDeForce: Correct! Two of each.
I'm soo tight with cash..I only need one so I'm gettin one of each I'll def. change the other too later on..hopefully
Posts: 768 |
In that case I would get down there and make sure you actually do need the parts your "tire guy" thinks you do. if his comment about alignment is any indication, then I would try to triple check what he says.
Posts: 669 |
Why is it so many have these cars and are tight on money LOL. I am going through the same thing right now (not money) Suspension issues. I am simply waiting for a warmer day and time to get the parts.
1999 Mystique Sport 2nd owner bought it in Sept 03 120000km 4 door, leather, loaded pics on cardomain, coatsy
Posts: 2,163 |
#13 requires a subframe drop. Are you sure you want to pay 300 bucks to install a 10 dollar part? While the suframe is dropped maybe you should replace all of the subframe buishing. I think that there are six.
Posts: 9,872 |
for installation, does car need to be on load or I can take the tires out??
Posts: 768 |
links? both on the ground (more or less level) or both off the ground. probably easier w/ front end up on jack stands and wheels off.
