Page 5 of 6 1 2 3 4 5 6
#1109378 11/23/04 08:11 AM
here u go
mph = (rpm x tire diameter) / (gear ratio x 336)
i got this from this site
http://www.prestage.com/community/Car+Math/Car+Math+Formulas/default.aspx
98 svt sil/blu 3.0 oval heads full P&P, msds headers,bat kit,2,1/2exhaust 30 inch glasspack and 2 spintech mufflers 14.78@94mph with my mechanical arm i can shift gears in less then a twentieth of a second for sale $7000
#1109379 11/23/04 08:16 AM
Originally posted by NorCalCoug:
We'll account for the following.
#1: His tire size is .6% smaller than stock
#2: Stock speedo is off by about 2% to begin with.
#3: He has the Zetec final drive, which bumps his top speed before hitting rev limiter to about 163.
4. A stock SVT Contour is limited to around 148-150mph due to the rev limiter more than the drag itself. It has more power than the Cougar by 30hp which is enough to break the 143mph drag limit.
5. Makes sense to me. So with 40-50 more HP than a Cougar (at LEAST, since we're talking a hybrid here and not just a straight 200hp 3L swap) and a taller gear with his final drive,
6. I don't see why there's all this hullabaloo that he managed to go a measly 13-15 miles per hour faster than a Cougar which has a HIGHER drag coefficient and LESS horsepower.
Let's not fight over stupid simple logical equations, people.
1. .6% = 2mph deviation from base calculations.
Everything is calculated in the PCM and TD is only one variable.
2. Your are wrong in thinking it's a fixed deviation.
The speedo is actually very accurate up to about 60mph. Within 1%
From 60-80mph it gets steadily worse from 1-3%
From 80mph on it exponentially gets worse and the more "off" the bases for calculation are the worse the deviation becomes.
RPM from an OBD-II hookup is the best indicator for true speed. Then back calculate mph using the simple formula and ACCURATE DATA.
3. Talk about bad math.
Using stock TD and gearing the SVT is rpm limited to ~164mph at 6900rpm.
While adding the Zetec (3.84) will raise the rpm limited top speed (~173mph) if you don't have the POWER to push the gear it will drop your top speed ability because of the loss in multiplication factor.
Drag limited means your power * gearing can not over come drag. If you lower the gearing you lower your work output and thus top speed ability.
Now if the car was rpm limited in top speed then a taller gear would increase top speed ability.
4. The SVT is drag limited to 143-144 mph. Tested by several magazines with a radar gun. 'nuff said
NO 170HP Contour or Cougar was EVER radar tested to 143mph.
5. He has ~185 FWHP. (225 crank) 25 HP over a stock SVT WILL NOT EVER gain 16mph in top speed even including the torque gain. Honestly not even enough to make 150mph.
Also there is no proof the splitter doesn't add drag or at least improve nothing at all. The SVT already has a very good underside deflector to keep air from pocketing in the engine bay.
The lowering will help.
Wider tires will hurt.
6. A MEASILY 16mph faster???
Let's do some basic equations.
Let's say he lowered CD to .30 (not likely but let's run with it) and using his 185 wheels he could theoretically reach 150mph if the gearing put him at max HP at 150mph
You see it's not just what max HP you make but what the rpm to "total" gearing factor is.
160mph would need about 230 wheels. (~280 crank)
Conditions being absolutely perfect of course. (i.e. bench racing equations!) So figure a fudge factor of 5-10 crank HP.
#1109380 11/23/04 08:24 AM
Demon, given all the great info you have posted...theoreticly, with the info i and other have provided, if the 160mph i hit is wrong on the speedo, what do you think i really hit??
Lupe
#1109381 11/23/04 08:33 AM
N
N
So I guess (in the NECO thread that you never replied to my post to) the "road safety" radar detector on the freeway that I blew past at 143mph according to the detector(145 on my speedo) was wrong, right? By the way, this was a stock Cougar ATX.
And yeah, I'm obviously lying, because everyone knows that Demon is the god of all knowledge. Nice, okay, so a magazine tested the car at 144mph. But these are also the same magazines that post incorrect horsepower ratings and so forth. Do they list all of the conditions during the test? Weight in the car at the time, other conditions such as barometric and temperature readings, etc?
There are other limiting factors, such as air density (which affects drag) and temperature, which can and will have a bearing. My speed was hit on a dry, cool night in the middle of the desert, which means less dense air (as far as molecular saturation from water).
Here, why don't we leave it at this. You can all think that he didn't hit the speed he hit. That's fine. I'll go on believing it, as will him and his fiancee who was in the car with him at the time and saw it.
We'll stop talking about it and then everyone else can go on living in their own dreamworld, kind of like how everyone who voted for Bush can go on pretending that he's a good guy, and an OK dude to be President.
2001 ATX V6 Dark Shadow Grey Merc Cougar(Sport Pkg, ABS, traction control and sunroof )
#1109382 11/23/04 09:15 AM
JB1 Offline
there is only one way to solve this once and for all. repeat the event under controled legal circumstances and no one will be able to argue. i am thinking something along the lines of how motor trend does top speed tests.
a fixed accurately measured distance covered in a given amount of time will give you your speed.
00 black/tan svt, #2052 of 2150, born 2/1/00 formerly known as my csvt "Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
i went with a 205,50,16 tire size
4th gear
mph = (6400rpm x 24.1") / (3.84 x 336) =119mph
5th gear
mph = (6400rpm x 24.1") / (2.88 x 336) =159mph
so were u in 4th or 5th gear?
if u were in fith and hit fuel cut off then id say u hit 160mph congrats
How the hell did this mathematical crap talk ended up when this post is about someone offering carbon fiber hoods!?
-dan
98 CSVT 484/6535,18" MI Rims,Nitto NEO GEN Tires,Pioneer DEH-P7300,Custom Cougar CIA,CF Hood,McCULLOCH HID 6K,Custom painted red calipers,Flowmaster 40s mufflers,Drilled Slot rotors,K&N 9" air filter,Brullen HiFlo Y Pipe & CAT,Magnaflow Res
-dan
Book'em Danno!
dion 98 SVT, 200 whp/190 lb. ft tq (tuned by ADC), 3.0, P&P heads w/2.5L valves, optimized TB, MSDS, SCA 2.5" catback, SHOshop UIM/LIM, underdrive pulley set, TD's, Koni/H&R, BAER/TCE, Progress, CF1 products
-dan
word! Back to topic, how much do you think it'd cost to just paint the hood?
Totally sold out for a 90 GT vert.... 1/4 mile is almost the same as my modded svt w/n2o was...
$300 + paint $325
Moderated by  Fmr12B_dup1, path914
