Page 2 of 3 1 2 3
Originally posted by Nebaukanezzer:
I know theres an AEM civic intake with takes the filter all the way down by the bottom splash sheild...why don't we run a pipe up under the battery and towards the front grill?
Thats what I was suggesting....would could build a duct which feeds through the hood into a airbox/heatshield of some sort.
Sort of like the second picture in my last post.
Is this what your talking about or something different?
I would have to agree about the headlight thing, couldn't do without high beams unless I used my car strictly for racing smile
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
JC, looks cool....but metal conducts heat...under the hood of our cars, yo umight be doing more harm than good, no?
Chris, that's definitley cool...I think I saw pics of it one time, but I can't remember.
But anyway, there's plenty of cars out there with functional hood scoops...there has to be a way to keep out water! Perhaps lying a sheet of something over the filter, at an angle to let water drip down, under, and drain out without ever touching the filter. Probably would interrupt air flow, but it's better than what's there.....now my wheels are turning lol!!
1999 Silver Frost SVT
#609 of 2760
Born on 12/3/98
KKM Intake
Removed Resonator
35% Window Tint all around
Tinted Tail Lights
ElKy Mesh Grilles
HID
Dyno'ed at 175.3HP/155.5TQ
I was thinking of getting the pipe/can covered in Carbon Fiber or something like that....Would that help at all?
Justin
1998 Black SVT
I plan on looking at cutting into the wheel well to accomodate the short ram intake setup similar to Integras. This will at least eliminate the heatsoak issue. Especially with everything else I plan to have generating heat in the bay.
Atttach a Weapon R to the Intake Tube and a noticeable difference should be seen over the open filter in the bay.
Also, I am interested in that "Revolution" carbon fiber intake for the Hondas. But it will not fit into the space that is in the Contour. It sure would look great though.
1998 Contour SVT ?/?/?
1995 BMW M3 PNP/NOS/Intrax
1970 Chevelle 454 SS Too Much.
Originally posted by Chris Hightower:
I am in the process of fabricating a scoop into a headlight for another CEG'er. The bright section of the drivers light has been removed and a fiberglass scoop will be molded in it. The battery has been relocated so that gives more space. Once it is intalled, I'm sure pics will be available. The cool thing is, I'm making a mold for the scoop so it can be replicated.
Chris this sounds like an excellent idea. It would work superbly at the track. But then so would removing the headlamp and having an open element reside behind the area (w/ battery in the trunk). I would like to purchase this item however, please let me know if it seems effecient. It certainly would funnel the air if guided correctly after the "nostril." Sounds very interesting.
i was thinking that the best way to do it would be to put a big hole in your upper grille, towards the side of your intake. the only reason i can think of why nobody has done this yet is because of looks. i'll post the pic later...they did that with the rapid fit mondeo.
No car anymore ;\ (taking a break from driving due to several misfortunate occurances)
Newest mod for my Dad's Cobra 'vert: My beautiful girlfriend and I for passengers when we want to go somewhere laugh
Alright guys, here is my outlandish idea. I stated it once before, but it didn't get any response.
If you could somehow have a KKM with a tube attached to it
(__________)<===---MAF
tube kkm maf
And on that tube have a bunch of coils run around it. The coils that are used on refrigeration could be wrapped around the tube A LOT, and very tightly. Also, I don't know if it's possible to use some sort of different fluid inside the coils that is extra super cold.
Now as far as doing this, I haven't a clue, just an idea!
Andy
STD's are like Pokemon...
Gotta catch em' all!
Administrator
Administrator
LF, sure it would work, but the problem is keeping it cold. If you were to try to rig up a way to keep it cold in the car, it would take more energy to keep the fluid cold than you would get from it being cold, so a net loss. but if it were a setup where you would pour, say some liquid nitrogen in there just before a 1/4 mile run, it would be great, but would last any longer than a single 1/4 mile run.
It's all about balance.
bcphillips@peoplepc.com
The AEM cold air I was talking about for the civic would be the equivalent of routing a plastic pipe down under the battery to the area above the splash sheild behind the foglights on an SVT model
Originally posted by 99SESPORT:
First off, if somebody is grabbing your nuts, your gonna do everything you can to get him off...
And sitting there telling him politely
"Please let go of my nuts, sir?"
9
9
My idea for a cold air intake without cutting into the hood is as follows:
1. Remove Battery and remount it into the trunk.
2. Fabricate an airtight plexiglass air box from the 3/8 in or 1/2 in plexiglass if you can find it that will fit into the space. I suppose an adequate volume would be about 1.25 to 2 cubic feet or so...two would probably be way too big for the space...but lets keep going.
3. Allow access from the top of the box using a sealable lid and secure latch and hinge.
4. Mount the largest K&N open air style filter in the box...I think about an 8 to 12 inch cone style would be plenty. Use a conical or cyllindrical...it doesn't matter. The most important thing would be the inner diameter of the filter outlet. It would need to be large enough in diameter to flow enough air to supply the engine at WOT without restriction, but not so large as to kill intake velocity. I am thinking like 3.75 to 4 inch.
5. Through the bottom of the box, cut two 3.75 in or so diameter holes and run flex tube (similar to the tubing used to route cold air to brakes in racecars) to a NACA style flush mount bumper vent (looks like an A/C vent opening for your house only its plastic behind the lower grill, right next to your oil cooler. Removing the black plastic trim piece that is present in the grill area beside the fog light would be necessary to open up air to the bumper section to which I am referring.
6. (Optional)coat the air box exterior with some sort of heat reflective material.
Now it gets Tricky:
7. Mount a 4 in intermediate pipe to the filter inside the box...you will need to put a silicone coupling on the outer side of the box on the pipe to seal the pipe and keep the filter from moving.
8. Behind the intermediate pipe (which is running towards the strut tower) Mount a Pro M 75 mm or simialar MAF that is correctly calibrated for your injectors. Mounting it here instead of right behind the filter will allow the air flow to have increased in velocity a little bit and, more importanty, allowed the air flow to smooth out into one direction for accurate reading.
9. Using mandrel bent pipe, build the elbow that is to turn the angle from the box to the Throttle body. The bend may not be a full 90 degrees, so a couple of different mandrely sections may be necessary. You would probably be fine with buying a J section and a U section. 3 inch exhaust piping can be ordered from summit, or perhaps you could even go larger. I would build it in sections, tied together with silicone couplings for easy removal.
10. After the bend, place a step down transition pipe that will decrease the diameter of the pipe to match the diameter of your chosen TB as closely as possible. This pipe would be similar to Aussie's Aussie Pipe, and would contain the necessary nipples for the relevant vacuum lines.
11. (optional) Have the entire pipe section Jet Hot Coated or perhaps wraped in hi temp exhaust wrap to cut down on heat soak.
There you have it. A real idea for a cold air intake that wouldn't starve itself for air, would provide decent protection from heat soak, would prevent rain from entering the intake (unless you hit a really deep puddle...then it could be hydo-lock time) and could even build up very modest air pressure levels during high speeds (ram air) You would want to mount the filter as high in the box as possible to prevent water intake should water actually pass up the vent and through the tubes....the theory being that the car would choke down before water is sucked in.
I have been asking for help from different local shops to help me, but no luck so far. Maybe its something my Atlanta contour buddies can help me with one weekend.
Former owner of 1999 SVT Contour #555
Page 2 of 3 1 2 3
