#110605 12/07/01 05:22 PM
9
9
Can anyone say for sure if the y-pipe is a good addition to do or not? I've heard that it causes a power loss and not a gain,or not enough of a gain to justify the money and that the mystery mod is a better way to go. wink
96 SE V-6 MTX
SVT E1 rims,205/55/16 Comp TA VR 4's,custom exhaust,KKM filter,bullit fuel door
painted calipers,trans cocktail mix,tinted windows/body coloured grill/engine cover/SVT door sills
#110606 12/07/01 05:53 PM
F
F
by far the best mod I've done so far, I got the off road y. I noticed instant torque but you must get a betterr exhaust setup than stock because the y-pipe creates much better flow thus creating more backpressure (with the stock exhuast set-up)less power on top.
Thanks
Eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's*
B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers.
Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
#110607 12/08/01 01:10 AM
E
E
Actually you may lose a few ft.lbs of torque between an exhaust and y-pipe. The diameter of the Borla/Bassani is 2.25" vs stock 2", therefore you get less backpressure at the cost of 2-3 ft.lbs of torque. Of course you make up for that loss in you horsepower figures.
I went from just a KKM, and added my Bassani and gained ~5hp. but lost ~3 ft.lbs of torque. When I put my Y-pipe on (SHO Shop Off-road) I gained ~2 ft.lbs back, and gained about 3.5 hp.
Click here to see my last dyno plot.
I also had to add a resonator after I went with the off-road pipe, there was too much drone and it got raspy in the upper RPMs. So all in all it cost me about $200 for the extra 3.5 hp, not including installation and reapir after the flex joint broke.
Hope that helps some.
2000 SVT Contour - Silver # 1675/2150
svt1675@comcast.net
This Shine brought to you by the letter "Z" for Zaino
#110608 12/08/01 08:29 AM
good dyno info! thanks.
however, i still beleive it's worth it. it breathes so much better at higher rpm's....just very nice!
later! laugh
#110609 12/09/01 12:35 AM
What if I put just the y pipe on my 96 contour 2.5 V6 atx and leave the rest of the exhaust from the converter stock how much will I gain in hp and tq
