jsny Offline OP
Does anyone know what it should cost for labor on a clutch replacement? I already have a different clutch and flywheel available for my 98.5 SVT. Dealer wants $1000 just to crack it open and confirm whats wrong with it plus ~$400 extra to do it. Talked to someone else and they wanted $850 for labor. Much better deal but still wondering if it's high. Thanks in advance for the insight.
Jeff
cleanslatewallpaper@yahoo.com
That sounds about right. The going rate for a clutch on a front wheel drive car is 8 to 10 hours multiplied by the shop labor rate. Contours are harder than most front wheel drive cars.
It does sound more or less right. You might want to find someone who specializes in manual transmissions and ask them, not just a 'transmission shop' though as I've found they know little more than the basics outside of autos!
I must admit, in the past I've looked specifically for 'classic car' automotive mechanics. Hard to find, but usually more adept that the rest.
1998.5 T-Red on Midnight Blue SVT Build Number 5320 of 6535
i see your in michigan, perhaps he should contact Terry Haines for more info. Is this post going to get locked now because I said this?
I Had Mine Done For 600$ By A Transmission Shop and that price includes some miscelleneous items such as bolts that were siezed and had to be broken and replaced....There Are Cheaper Rates Out There, Keep Looking...
CSVT E0 3L 14.5 @ 94mph, Stock Intake, Stock Exhaust minus Resonator, CEL, And Broken Pass. Side CV...Untuned.
9
$600 did that include the clutch? If so that was amazing!
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
No Did Not Include Clutch...Paid 340$ For Spec Stage Three Set Up..
