#110241 11/30/01 06:56 AM
Basket Offline OP
FPS Automotive out of Atlanta sells aluminum bushings for the front subframe on the SHOs. My buddy (who owns what was previously my 1989 SHO) just got a set and he says the difference is phenominal. I was curious if these are available for the SVY. I would assume this could help alleviate the subframe shifting problem which leads to the pulling right situation that so many have complained of. I keep having the TSB performed, where the subframe is right and then the pass. side is moved forward, but I'd rather not have to do this every 7000 miles or so.
2000 Toreador Red SVT
All Mods Except
Vortech
Quaife
HP Clutch
Light Flywheel
E
E
Oh! Solid subframe connectors are bad. My friend had a set on his `91 SHO. The difference was amazing.
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
