Posts: 1,384 |
Originally posted by TronX: Mine is always out of wack. I get like 250 ~ 285 at best from full to empty. I've changed everything I can think of other than the coil. So when I hear of people getting 300+ it make me sick to think there has got to be something I've missed.
I really don't think the contour or mystique get good gas miles without some tweaks.
Damn brutha, that's about 16-20mpg. Do you have a cel? I'm not going to say anything on this post, b/c im getting pretty damn good mileage on mine, but I do drive almost all highway. I do about 65 miles/day, and 5 miles are probably city.
And about the tweaks, my car shows that you're correct. When I got her at 35k, she was doing 26mpg/highway. After intake and SVT exhausts (no resonator), now at 52k, I'm doing about 31/32mpg, mind you on an ATX.
99 Black Contour SE Sport
Posts: 135 |
This is purely anecdotal, but a can of Techron concentrate to clean out the injectors usually does my gas mileage good. Yeah, it costs around $12, but given gas prices these days, it'll be made up quickly.
Po
Po
1995 Mercury Mystique GS: Zetec 2.0L I-4, CD4E
1978 Ford Thunderbird Town Landau: 351M (5.8L V-8), FMX
Coming in 2007 -- 1986 Jaguar XJ12 Sovereign: 5.3L High-Efficiency V-12, GM transmission
Posts: 937 |
Originally posted by ancientsanskrit: Originally posted by TronX: Mine is always out of wack. I get like 250 ~ 285 at best from full to empty. I've changed everything I can think of other than the coil. So when I hear of people getting 300+ it make me sick to think there has got to be something I've missed.
Only one code P1381 and that is the VCT.
I use to fill up once a week and for the last few years it's been more like ever 4 or 5 days now.
There is a noise that I can hear when the car gets hot. Sounds like a pin whole sized air leak, but I can't find it. Do you think this would cause anything? I'd think there would be a new code if my car was really that far off.
I've got my own code scanner and I can't tell if the car drives any better or worse when the VCT code is removed. It normally takes about 2 hours of driving before the codes sets off. My guess is that the VCT can't adjust enough oil pressure to regulate and adjust the cams when the engine is fully hot. I'm sure the leak does not help either. Now that I think about it the VCT started going off one day when the car ran over big bump in the road and the bottom of the car slammed really hard into the road.
Hmmm.. maybe the bump cause a crack in the exhaust or header? But would this effect the VCT because it can't adjust enough to match the leak? Or are they not even related.
I've got many questions as you can see.
Does the VCT code cause the car to use more gas?
Posts: 2,725 |
Originally posted by renatonetmail: I personally hit 300 miles driven with still 1/4 Tank to go. I guess cuz of all the maintenance and tune-up and hell am not granma driving... hehee
We have the same engine and trans, and thats what I used to get about. I drove to Chicago and back 175 miles each way, and about 20 miles in Chicago, so about 390 and the thing was just about on redline, I dont understand what happened to this car overnight.
Posts: 937 |
Originally posted by HITMANinMI: Originally posted by renatonetmail: I personally hit 300 miles driven with still 1/4 Tank to go. I guess cuz of all the maintenance and tune-up and hell am not granma driving... hehee
Dam... when you find out what is wrong let me know so we can all get this fixed..LOL
There must be something we can do about this?
I've done everything like fuel filters, plugs and wire and replaced the PCV valve.
You know the last time I was looking at my TB before I had the PCV valve replaced there was a whole from the top on the right side. It was all caked up with gunk and so I spayed some Air-intake into it and that is when I later found the PCV air leak. I'm not sure what this little side chamber was for inside the TB? My guess is that it was another air return chamber of sort? Hmmmm...
Posts: 197 |
i figured out mine last year on a 500km trip that was all expressway and after i convereted it i was getting about 32 mpg and my car is all original
RIP Frank Foreman. March 15 2005. died in a tragic car crash at the age of 18.<Drive Safe>
1995 Contour gl Zetec auto.
178000km
Posts: 143 |
[censored] zetec contours getting better gas milage  . I get close to 30 highway with my SVT, but don't come close to ya'll in the city.
The greatest stealth car ever... CSVT
1998 2.5L V6 MTX
KKM intake with BAT pipe
Magnaflow resonator
other Audio enhancements
Posts: 8,301 |
Originally posted by BCSVT: [censored] zetec contours getting better gas milage . I get close to 30 highway with my SVT, but don't come close to ya'll in the city.
My highest so far is 38 MPG on a road trip, but I usually get about 35 driving easy with mostly highway and some city driving.
-Ken V.
psycho_bass@hotmail.com
Posts: 246 |
My best was about 36-38 high way going from san diego to Denver. I only had 25k on it now i have 94k and i pray for 20 MPG with a mix of city and highway. I am current on my tune ups, but with the searching i have done I found out that it may be time change the IAC Valve.
Troy
99 Contour SE Sport
Posts: 20 |
I get 26-28mpg with all back roads and city driving...no highways at all. My 1995 Myst has the 2L and the auto tranny and 100K on it. Alot is how you drive...esp with the auto tranny's....and some is tire type. I check the mileage every time I refuel and she's pretty consistant.
