You need to verify proper alignment of the wiper arm. Remove the blade assembly and position the wiper about halfway across the glass. Lay the metal hook on the glass. It should lie flat. Take a piece of paper and try to slide it between the glass and the hook from both sides. Use some pliers to gently twist the arm as needed. Then clean the glass well (like someone else said) and put on some new blades.
