Posts: 72 |
HOW????????????????????????????????????????? My hands hurt and if i get into the "beast" mood i would "eat" the screw with the screw driver bit
___________________________
'95 Contour GL 2.0L (170K) A/T
Posts: 2,033 |
Uhh, you take the right fitting screw driver, and LEFTY-LOOSIE....RIGHTY-TIGHTY buddy!
Posts: 72 |
Originally posted by getlucky151: Uhh, you take the right fitting screw driver, and LEFTY-LOOSIE....RIGHTY-TIGHTY buddy!
The theory i know it ... but if fly you to NJ and you apply it?? ... hahahaha lol... this stuff is TIGHT...REALLY TIGHT !!!!
Posts: 1,788 |
Vice-grips.
Pretty common for those things to be extraordinarily tight.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 22 |
Accually, you need a hammer driver. You can get them at the auto parts store. You just put the bit in you need and smack the base with a hammer. The driver is spring loaded and turns every time you hit it. It takes some doing but it will come out. You can use vise grips once the screws are out a little. Advise: Once you remove them replace with a different, shorter screw with an alan head.
Did I really buy this car?!?
95 Contour GL 2.0
91 Explorer EB 4.0
Posts: 72 |
Originally posted by hallboy: Accually, you need a hammer driver. You can get them at the auto parts store. You just put the bit in you need and smack the base with a hammer. The driver is spring loaded and turns every time you hit it. It takes some doing but it will come out. You can use vise grips once the screws are out a little. Advise: Once you remove them replace with a different, shorter screw with an alan head.
got any link of those to check it out thru the internet?
Posts: 1,012 |
Yeah...obviously you've never had to unscrew these things. I finally just drilled the [censored] out and bought new screws.
Posts: 72 |
Does someone know if after take the TPS this thing has a gasket or something to change beside the sensor itself???? I gonna pass by PepBoys today to look for that hammer driver tool...although i still have no idea how it looks like.
Posts: 2,779 |
i've taken off a few SVT TB TPS's in my day...no problems yet. A simple screw driver does the job, it helps to have one that correctly fits.
Posts: 72 |
Originally posted by JonnySVT: i've taken off a few SVT TB TPS's in my day...no problems yet. A simple screw driver does the job, it helps to have one that correctly fits.
I guess non of those had been THIS [bleep]ing tight... serious...i have a set of bits and am using the proper one but those mother[bleep]ers dont want to go loose.. Arghhhh ....i donkt know what to do ....
