Originally posted by ZetecNinja:
Originally posted by pole120:
some wheels come "double drilled" with two different patterns on one wheel, and in my experience 4x100, and 4x108 are comonly paired.
this means ther are 8 holes, 4 in a 100 pattern, and 4 in a 108 pattern, if these wheels also have a 108 patern, you should be able to use them, but check the offset as it may cause other problems.
most likely going to be 4x100 and 4x114.3(?) I think thats the other common offset.
doubtful they're paired together. if i had to guess i'd say its paired with a 4.108, but i could be wrong. i know at work all of the fingers we use on the wheel balancers are paired w/ 4x100/108
'03 SRT-4 50 trim turbo + support
