Posts: 216 |
So far all I have is the kit. What else will I need in order to run safe without spending lots of $. So far I need a purge line, a A/F guage, and what else?? Any help would be greatly appreciated!
00 Audi S4 Silver and Black (Bone stock)
98 Toreador Red SVT #742/6535 (Totalled)
KKM induction,Sho-Shop Y pipe, removed resonator, Superchip, B&M Short Shifter, Fog Light Fix 885 Fogs, Xenon Super Whites Clear Corners w/clear bulbs Removed Door Dings, TH Fix, ADR Phase II white 17s and Kumho rubber
Posts: 268 |
One step colder spark plugs. Maybe some new wires also.
I am going with an oil pressure and nitrous pressure gauge too.
Stormin' Norman 2000 SVT 17" AT Italia Spa w/ Kumho 215/45-17 VCN-2000 Eibach Springs Bassani Best #'s so far- 268.5HP and 275.8 ft-lbs at the wheels #463/2150
Posts: 4,319 |
Get an FP gauge instead of OP.....
1991 GVR4 Lots of mods done.
Posts: 268 |
I have been going over the FP or OP for a while. Half the people say FP the other half say OP because of our oil starved cars. I think that I might get both and place the nitrous pressure gauge down by the cup holders.
Posts: 4,319 |
Originally posted by Stormin' Norman: I have been going over the FP or OP for a while. Half the people say FP the other half say OP because of our oil starved cars. I think that I might get both and place the nitrous pressure gauge down by the cup holders. Both of you: Do you plan on a 3 gauge pod? Also, consider a heater as well.
Posts: 268 |
Yes, I have already ordered it.
Do you know if the Venom system needs a bottle heater to? Or a purge system for that matter? I am just starting to gather up the parts.
Posts: 4,319 |
Originally posted by Stormin' Norman: Yes, I have already ordered it.
Do you know if the Venom system needs a bottle heater to? Or a purge system for that matter? I am just starting to gather up the parts. The venom system is nowhere near as dependant on bottle pressure as Zex is. Therefore, heaters and purges not needed.....
Posts: 1,151 |
T-RED, some q's I forgot to ask while I was down. Where do you run your nitrous line? Where does it penetrate the car? Is it run under the car and up into the engine comp? If you could send pics of those parts of your install I would appreciate it. By the way, how do you like the 100hp shot?
ChickenhawkRacing@hotmail.com 1998: #4415/6535 mods: Sheet metal screws in rear chrome strip Four wobbly corners "Hey, do you like apples?" "Well, yeah." "Well, I got her number, how do you like them apples?"
Posts: 4,319 |
Jon,
Lines are run under the car from the trunk to the engine bay. I'll try and take some pics. Also, the 100 shot is bueno. Ran a 14.12 with her in.....
