Posts: 109 |
You don't happen to know what the code is for a 1998 Zetec do you?
Or where I would look to find out what it is?
Wijn
1998 tour Zetec
B&G springs cut 1"
17" Amp "tech-9" rims
Pro tint
2 1/4" exhaust
Autometer tach & Euro Guages
CTA/weapon R combo intake
Zex Dry Nitrous kit
Posts: 21,653 |
On the computer. Passenger side, behind glovebox sorta (in footwell). Remove bracket and read code.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 1,860 |
It's MML0(zero). The way the chip sits in the ECU is not the problem. Both diablo and SC use the same hardware to attach to the J3 input on your ECU. It just looks different from the outside. The most likely cause of an intermitten failure on a chip is a J3 input that was not cleaned correctly for the initial install. Pull the computer and disassemble it using either a 5.5mm or a 7/32 socket. Next get a piece of sandpaper or scotchbrite pad and get ALL of the pins on the board to look copper colored. You don't need to sand a hole in the board just make it copper. Then try it again. If that fails I suggest getting your hands on a data logging scanner and check to see that your O2 sensor is cycling properly and that the fuel trims are not too far away from 0. If that all pans out then I would suspect a vacuum leak or your idle air control.
2001 Lincoln LS8
1994 Lexus GS300
Posts: 21,653 |
Originally posted by Keyser: It's MML0(zero).
Wijn, Keyser is talking to RG not you, your code will likely be different. just fyi.
98.5 SVT
Posts: 5,621 |
Originally posted by Keyser: It's MML0(zero). The way the chip sits in the ECU is not the problem. Both diablo and SC use the same hardware to attach to the J3 input on your ECU. It just looks different from the outside. The most likely cause of an intermitten failure on a chip is a J3 input that was not cleaned correctly for the initial install. Pull the computer and disassemble it using either a 5.5mm or a 7/32 socket. Next get a piece of sandpaper or scotchbrite pad and get ALL of the pins on the board to look copper colored. You don't need to sand a hole in the board just make it copper. Then try it again. If that fails I suggest getting your hands on a data logging scanner and check to see that your O2 sensor is cycling properly and that the fuel trims are not too far away from 0. If that all pans out then I would suspect a vacuum leak or your idle air control.
Hey Keyser, appreciate your help. I been suspecting the same thing - b/c when the chip was initially installed - it wasn't done by me, so I have no way to check whether the ECU was really removed - and as the SuperChip Web site states, "The hole exposing the contacts is not large enough to clean the contacts sufficiently" unless the computer cover is removed.
Now I can't get on Chris' Web site ( Chris' How-to ) to get the how-to for removing the ECU - the web site doesn't respond. I remember that after removing the white holding bracket the power steering reservoir has to be removed but that's it. Anybody got the "back-up" version? Thanks.
Now the last thing that baffles me - and I been posting this before - why every and each time I am getting this mysterious engine stalls - it keeps happening ONLY when I am coming back from work (never on my way to) and ALWAYS on one particular place? I wouldn't believe it myself unless I was in the car driving. Been happening for over 6 months now...
Posts: 21,653 |
Just something to do with how it warms up by that point and all.
98.5 SVT
Posts: 5,621 |
Yeah, that's what I thought but still scary man.
