Checked the cable and noticed there is about 2 inches of wire loose at the end, I think the cable wire is not retracting. Unscrewed the 4 screw on top of the imrc box, somehow I can not lift the top plate and inspect inside if it is broken spring of cable.
Is cable wire should be tight? How to open the imrc box? Is there easy fix (DIY)?
I got the code after I moved the imrc to replace the plug and wire. It is 98 svt with 100k.
