Posts: 36 |
I want to change the serp belt, do I take that big metal bracket off near the timing belt cover? I guess I can see the belt tensioner after that?
The oil change was easy once the wheel and plastic cover was removed. I noticed all the cracks in the belt with the cover off too.
Posts: 2,725 |
You dont remove that. You go from the bottom up.
Posts: 880 |
There is also a "special" tool you can get to help releive the tensioner so you get get the belt off. I got it from Autozone when I did mine.
-Black '96 GL 160k
-Car #30953
Posts: 21,653 |
Originally posted by BenS: There is also a "special" tool you can get to help releive the tensioner so you get get the belt off. I got it from Autozone when I did mine.
You don't need a special tool. Just a breaker bar and socket.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 937 |
Originally posted by Kremithefrog: Originally posted by BenS: There is also a "special" tool you can get to help releive the tensioner so you get get the belt off. I got it from Autozone when I did mine.
You know I've got a breaker bar (long socket wrench without ratchet). I got it once to remove the wheel hub nut. I don't know why, but I thought I had to remove this nut to get the Rotors off.
Does anyone have pictures? Step-By-Step How To's?
Posts: 3,395 |
Just a 13 MM Craftsman wrench, some muscle, and some knowledge on how to install a belt, worked for me  Just replaced mine with a Goodyear Gatorback
Posts: 1,459 |
Yep. Remove the right front wheel, remove the lower fender liner (or whatever that lower plastic guard thing is called), and a good box end wrench will do the trick. It takes a fair amount of leverage, but nothing excessive. I use a standard wrench, probably 10 inches long.
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 5,143 |
Originally posted by ContourKev: Just a 13 MM Craftsman wrench, some muscle, and some knowledge on how to install a belt, worked for me
When you do it, use a goodyear belt... They make your car sound like its gotta supercharger when you hit the higher RPM's.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 205 |
By TronX: Does anyone have pictures? Step-By-Step How To's?
Here's a quick run down on how I did it:
Linky...
92 Talon TSi AWD
DSM= Daily Scheduled Maintenence
Posts: 937 |
Thanks man.. it looks easy when I've got pictures. And to think I've had to pay someone to do that on my car.  Is there anyway to make the tenisioner tighter? I swear everytime someone takes off my belt the car drives better until it loosens back up. I've got on a good Gates Belt.
