but you can always take longer bolts, put some thick rubber or plastic washers and reduce heat transfer from the block. iirc someone has this done. question is if you have enough clearance w/ the cooler.
personally, I think if the difference is masurable, it's laughable... now if you had alcohol cooler like in those "shuttle" computer boxes
