Posts: 1,050 |
I think they are advertising based on the dyno run from that cougar. They showed a 25hp increase on the cougar over stock. The dumba*ses compared a chipped cougar with the headers to a stock one, so you can't tell how much came from the headers, and how much came from the chip. By the way Icey Mike, I see your signature. All I can say is SEMPER FI!! I at least understand what it means to be a Marine. warmonger Former 2531 battery operated grunt.
You can call me anything you like as long as it's nice.(all lies accepted) 99 Silver Frost SVT. #226 of 2760 Engine: 3.0 power! Unique Stuff: Sunroof control module (#1 of 9) Car Audio: Loaded and loud! Check them out at http://home.earthlink.net/~twilson1726
Posts: 1,447 |
My personal opinion here; MSDS Headers, I waited a Very long time, once installed, the wait was worth it, I may go dyno this week, but I am not real sure about that. The key phrase here is Just Do It
Posts: 1,812 |
Knu - thanks. I need that. I'm currently waiting to receive...
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 268 |
I agree, even tho the numbers weren't what I expected, I'm still pleased with the overall performance. I like the way the revs build up quicker and the improved mpg was a welcome surprise!
98 evo 0 SVT #2999 of 6535 Silver Frost/Midnight Blue Lotsa bolt-ons
Posts: 64 |
What about combining the MSDS headers with the SHO Shop "Y" pipe? I have the SHO Shop Y pipe now, just got the Vortec MSDS headers....the Y pipe on the headers looks awfully restrictive, just like stock!!! Would this be a good combo or would we loose power on this setup as well?
Thanx
Smoke me a kipper..I'll be back for breakfast
99 SVT (Black) # 2642 of 2760 Mirko Racing Intake \K&N Filter (RU 3130) BAT Air Inlet Pipe HD Motor Mount Inserts \Front - Rear Sway Bar Bushings BAT 22mm (Rear) Sway Bar, Bat Springs \ Koni Sport Struts Performance Fords - Spherical Rod End Links (Rear) Performance Fords - Street Link SHO Shop Strut Tower Braces (Front and Back) SHO Shop Body Sub Frame Connectors Aeroquip Stainless Steel Brake lines (Front/Back) Sho Shop "Y' Pipe Magnecor Wires \ Bosch +4 plugs Ford Dual Mass Crank Damper Pillar Guage Pod Perma-Cool Remote Oil filter Mount Summit Racing Polished Almn Battery Relocation Kit MSDS Headers (not installed) B&M Short Shifter Sparco Pedals (4 pedal set) (I think I got 'em all)...someone sell me something else!!
Posts: 1,812 |
mikey - there was a guy who dyno'd w/ the MSDS headers and the SHOShop pipe, then with the MSDS pipe and the MSDS pipe had a few hp on the SHO pipe. Theory is that the bend in there is for extra hp...the stock pipe is just ugly on the inside.
Posts: 1,202 |
Originally posted by Derk2000: mikey - there was a guy who dyno'd w/ the MSDS headers and the SHOShop pipe, then with the MSDS pipe and the MSDS pipe had a few hp on the SHO pipe. Theory is that the bend in there is for extra hp...the stock pipe is just ugly on the inside. The power loss of the stock Y-pipe is how Ford crushed the pipes together. With a good flowing y-pipe, even with the bend, HP is gained. Here is that Y-pipe comparison installed on MSDS headers.
Posts: 64 |
Thanks for the info.....anyone want to buy a slightly use SHO SHOP "Y" pipe??
Posts: 414 |
Mikey. how much for the y pipe. E-mail me
98 EO #587 Currently Dirt Jumping
Posts: 64 |
Sorry guys! When I said I wanted to sell the Y pipe , it was kinda "tongue in cheek"! Not really sure if I'm going to get rid of it..want to go racing, depending on what type of car, class, and what my wife let's me do,I will make the decision as to whether I use it or not.
By the way, for those of you that asked, it's the y-pipe w/cat (aluminized steel). Again sorry for the false advertising!
