Posts: 3 |
GUYS,
I'VE BEEN ASKED TO OFFER HELP AND INFORMATION BY ONE OF THE OTHER FORUM MEMBERS MARK WHALEN.
FIRST, YOU CAN CONTACT ME @ VENOMGREG@YAHOO.COM WITH ANY QUESTIONS ABOUT THE USE OF NITROUS (REGARDLESS OF BRAND, I PROVIDE FACTUAL HELP, NOT SALES HYPE OR SCARE TACTICS).
MARK WHALEN WAS THE FIRST (AND AS FAR AS I KNOW) ONLY ONE OF TWO SVT'S WITH VENOM'S VCN2000 NITROUS SYSTEM. THE RESULTS SPEAK FOR THEMSELVES AS BOTH THAT I KNOW OF ARE PLEASED WITH THE GAINS THEY'VE ACHEIVED AND ALSO THE CONVIENIENT OPERATION AND USE OF THE SYSTEM.
I'M NOT HERE TO "PIMP" MY LINE, I'M HERE TO ADVISE ALL INTERESTED IN THE GENERAL RULES OF USING NITROUS.
I'M GOING TO COVER WHICH TYPE SYSTEMS OR USED FOR RESPECTIVE APPLICATIONS TO HELP DISPEL ANY MISINFORMATION.
THERE ARE TWO BASIC "TYPES" OF NITROUS SYSTEM. ONE BEING "WET", THE OTHER "DRY". "WET" REFERS TO A SYSTEM USING A DISTRIBUTION DEVICE (COMMONLY CALLED THE NOZZLE, OR FROM THE N.O.S. BRAND "FOGGER NOZZLE") THAT USES THE ENERGY OF THE EXPANDING NITROUS TO ALSO PULL FUEL THROUGH THE NOZZLE AND ATOMIZE IT AS THE NITROUS EXPANDS INTO THE INTAKE TRACT. THERE ARE REALLY ONLY A COUPLE OF APPLICATIONS WET SYSTEMS ARE APPROPRIATE FOR. THE FIRST BEING CARBURETTED V-8 OR V-6 ENGINES USING A "PLATE" TYPE DEVICE BENEATH THE CARBURETOR. THE SECOND BEING DIRECT PORT INTO EACH INTAKE RUNNER TO ENSURE CONSISTENT MIXTURE DELIVERY TO EACH CYLINDER. DIRECT PORT SYSTEMS ARE COMPICATED, BULKY, REQUIRE TUNING BEFORE IT'S READY TO RACE, AND REALLY ARE MEANT FOR PURE RACING APPLICATIONS DEALING WITH 80+ HP ON 4CYL'S, 150+ ON V-6, AND 175+ ON V-8 APPLCATIONS. SOME COMPANIES OFFER A SINGLE NOZZLE WET SYSTEM FOR USE WITH LATE MODEL FUEL INJECTED APPLICATIONS WHICH IS VERY RISKY AS THERE IS NO ASSURANCE OF EVEN FUEL DISPERTION TO EACH CYLINDER, HOWEVER A SINGLE NOZZLE "WET" SYSTEM CAN WORK OK ON TURBO OR SUPERCHARGED ENGINES IF KEPT AT 80HP OR LOWER. SUPERCHARGED AND TURBO ENGINES CAN ALSO USE DIRECT PORT BUT IT'S TRICKY TO TUNE DUE TO BOOST CHANGING THE FUEL PRESSURE CONSTANTLY.
"DRY" SYSTEMS WERE SPECIFICALLY DESIGNED TO MAKE IT SAFER, EASIER TO INSTALL, EASIER TO TUNE, ON FUEL INJECTED ENGINES. "DRY" SYSTEMS CAN BE DONE AS DIRECT PORT (FOLOWING THE SAME GUIDE LINES MENTIONED WITH THE DIRECT PORT WET SYSTEMS) OR AS A SINGLE NOZZLE. TO CLEAR UP ANY CONFUSION AS TO WHY A DRY SYSTEM IS BETTER (ON FUEL INJECTED ANGINES), THINK OF HOW THE MANIFOLD ON A FUEL INJECTED ENGINE IS DESIGNED. THE PURPOSE OF THE MANIFOLD IS TO OPTIMIZE THE AIRFLOW TO MAXIMIZE CYLINDER FILLING ABILITY OR THE AIR STREAM. MANIFOLDS FOR DIRECT PORT INJECTION ENGINES WILL NOT ALLOW ATOMIZED FUEL TO REACH EACH CYLINDER IN AN EVEN FASHION. (THAT'S NOT MY OPINION, IT'S A FACT) "DRY" SYSTEMS (FOR STREET CARS) USE A SINGLE NOZZLE TO RELEASE NITROUS INTO THE INTAKE TRACT UPSTREAM OF THE THROTTLE TO ENSURE COMPLETE EXPANSION PRIOR TO ENTERING THE MAIN PLENUM. THE FUEL INJECTORS ARE USED TO DELIVER THE FUEL. ON DIRECT PORT RACING SYSTEMS, THE ENGINE MANAGEMENT SYSTEMS USED TO RUN THE ENGINE ARE PROGRAMMED TO DELIVER THE PROPER FUEL VOLUME WHEN TRIGGERED BY THE NITROUS SYSTEM ACTIVATING. ON STREET CARS, THIS ISN'T POSSIBLE (WITH THE FACTORY COMPUTER). THE TREND HAD BEEN TO USE A DEVICE TO RAISE FUEL PRESSURE AT THE RAIL TO CAUSE THE INJECTORS TO DUMP MORE FUEL, IT WORKS OK BUT STILL LEAVES ALOT TO BE DESIRED. IT ISN'T EASY TO CHANGE THE TUNE UP AND KEEP IT RIGHT. ALSO (WHAT THEY DON'T TELL YOU) RAISING THE FUEL PRESSURE REDUCES YOUR FUEL PUMPS OUTPUT VOLUME, WHICH IS BAD WHEN YOU NEED MORE FUEL. ALSO, EXTRA PRESSURE CASUES ACCELERATED INJECTOR WEAR AS THE INJECTOR HAS TO WORK HARDER TO OPEN. TO COMPENSATE FOR THIS, THE OTHER COMPANIES ADVISE TO SPEND MORE MONEY (AFTER YOU'VE BOUGHT THE SYSTEM ASSUMING IT COMES WITH ALL YOU'LL NEED) ON HI VOLUME FUEL PUMPS OR "BIGGER" INJECTORS. WHAT HAS BEEN NEEDED IS SOME TYPE OF TRUE ELECTRONIC MANAGEMENT FOR THE FUEL SYSTEM WHEN USING NITROUS. OUR ENGINEER HAS INDEED DO JUST THIS. BOTH OF THE SYSTEMS OFFERED BY VENOM HAVE THE DISTINCT ADVANTAGE OF A COMPUTER DESIGNED TO MANAGE THE VEHICLE EXISTING FUEL INJECTORS TO A HIGHER RATE OF FLOW BY ADDING "PULSE WIDTH" OVER AND AVOBE THE STOCK ECU. ADDITIONALLY, THE SYSTEMS KNOW WHAT "LEAN" IS AND SHUT DOWN WELL BEFORE THE ENGINE WOULD SEE A FUEL RATIO SO LEAN IT MIGHT CASUE A BACKFIRE OR "BURN" PARTS IN THE CYLINDER(S) DUE TO EXCESSIVE COMBUSTION TEMPS IN COMBINATION WITH AN OVERABUNDANCE OF OXYGEN.
I KNOW THIS IS A BIT LONG, SO I'LL WRAP FOR NOW, AND AGAIN ANY QUESTIONS YOU HAVE EITHER VENOM OR OTHERWISE DON'T HESITATE TO MAIL ME
(VENOMGREG@YAHOO.COM)
THANKS FOR YOUR INTEREST. VENOM GREG.. VENOM RACING, OF, BY, AND FOR AMERICANS
Posts: 4,319 |
Welcome Greg! I hope to be one of ther next users of the VCN2000 system soon. Thanks for coming aboard to help out!
1991 GVR4 Lots of mods done.
Posts: 329 |
I have a few questions.
First, I'm a little confused by your description of a "wet system". My understanding was that additional fuel was "sprayed" in under pressure. Plate systems that I'm familiar with have seperate gas/fuel "bars". I don't see how "expanding" nitrous from one bar is going to "pull" extra fuel out of a completely seperate bar in the plenum. I thought thats why these set ups have a fuel solenoid, and are spliced into the cars main fuel supply line, [under pressure]. I thought "fogged" systems mixed gas/fuel together BOTH under pressure just as they were introduced to the cylinder. This is done, I thought, to create a more homogenous mixture than spray bars could achieve. Can you clarify this please?
Other than the added expense, and added tubing installation, wouldn't the "ideal" be a "dry" system, with a discharge nozzle placed in the intake runner for each cylinder, as close to the entry into the head as possible? I'm a little confused how a single nozzle at the throttle body area won't have cylinder to cylinder variations like the "plate types" due to manifold design.
I guess what I'm asking is, how much "expansion" is going on in the manifold at the instant of triggering? Is it so much that the placement of the nozzle is a moot point?
Thanks for coming by to get us up to speed.
blk.99svt n.e.Ohio Never under estimate the power of stupid people in large groups...
Administrator
Administrator
Posts: 4,527 |
Welcome Greg! good to see you here trying to help people that are interested in nitrous use. I have ridden in Mark's (Trapps') car and even helped him a bit w/ his install, and I must say I was quite impressed w/ the Venom as a kit. (btw, I may have even talked w/ you at a SEMA show before, but I'm not sure)
oh, and fyi, try to refrain from all caps, it is often used to imply the person typing is yelling, and besides, it can be a bit tough to read.
It's all about balance.
bcphillips@peoplepc.com
Posts: 972 |
welcome greg!
i run a zex nitrous system, but whatever, its nice to see someone here to help with our n20 problems, and stuff
95 SE Champagne Mettalic True Dual exhaust with X pipe and Redline mufflers KKM Tru Rev intake H&R Springs/KYB struts Apex-i S-AFC 65mm Throttle Body 17" Ace Spades 4 Pt Racing Harness Window Tint all around New Engine @ 117k kilometers G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass" quote from awed CEG'er after i chopped my hood and threw on scoops
RIP 98 SVT silverfrost *nov 4 2001*
Posts: 434 |
Welcome Greg ... now please turn off the CAPS LOCK
Posts: 1,682 |
Greg,
Do you offer a kit for the 01 F-150 Lightning? If so, can i get 2 bottles (10lb each)? what is the approx cost on a system with 2 bottles?
Posts: 74 |
Hi all:
I have the other Venom system. I have a very busy work schedule and usually don't have much time to make any posts. After seeing Greg's post I had to make time.
First, let me say that this is the best web site I have ever seen on any car. I don't know too much about cars, mechanically speaking. This site has truly opened my eyes, and unfortunately my wallet, to so many different aspects of my car. I thought my car was awesome before my mods. I just took it to Road America in WI. I ran with, even passed cars, WAY more expensive than mine.
I bought my system by calling Greg at Venom directly. He was very helpful and seemed like he was truly excited, and proud of his product. He said no less than four times if I need any help to give him a call. The most impressive thing about my Venom system is the support that I received after it's purchase. My friend and I installed the system together. We did it while we were at work. After we got the system installed it would not pass the O2 test. We tried to tap another O2 sensor. Still nothing: time for tech support. I called Greg the next day and he stayed on the phone with me while I tested various leads with my multi-meter. After exhausting everything, he said to ship the nitrous management control unit: brain, back to him. As it turned out, the brain had a bad O2 reader and they sent me a new one. I dropped it in and the system fired up.
I run it at about 75hp boost. When the system fires it's like someone gave you a solid push from behind! The performance gain is amazing. I have had the system for almost a month and have only used 2 bottles of nitrous. Now that it's chilly I'll be done for the season. The only thing that I might get next year is a bottle pressure gauge and a purge kit.
Also, I would be happy to answer any questions, with my somewhat limited knowledge, on the system. I will try to post some pics on my setup.
P.S. Thanks to Mark for getting the system set up for us. His TPS setting worked great for me.
Josh
98.5 Contour SVT
Posts: 32 |
Could u please post the address for the website?
'97 mkII 1.8 sedan, mtx, Diamond White, Magnecor KV85, clear side repeaters
Posts: 255 |
basic cost? will it work with atx?
99' contour sport atx,new pedals and mesh grill, 98 TSW Zenon 17x7 225/45/17 toyo proxes, svt front brakes,svt springs and struts,sho shop y-pipe no cat, and sho shop adapter for k&n cone air filter, sca 2 1/2" piping into two can styled magnaflows. http://communities.msn.com/DeviousContour/contour.msnw
