I want to install an oil pressure gauge on my Contour... Question is, anyone know of an FAQ (Did search, didnt find much for a Zetec, just Duratecs )
Anyone able to help out for a Zetec Install.
Pictures, and some basic things done would be helpful
Also what kind of T-connector to get.
I was thinking of getting an Electrical sending unit.
Also how much do they run in price?
(95 Zetec ATX Contour GL)
Former owner of a 1995 Ford Contour GL w/ 2.0L ATX Proud owner of a 2005 Ford Taurus SE 3.0L V6 Vulcan --Looking for Commodore stuff (Drives, Units, Amiga, games, etc)If anyone has any of this laying around and wants it gone, lemme know --
I was told when I thought about getting my fuel psi gauge to go eletrical. Not sure on the install however. but stay with eletrical.
95 SES Sold 99 SE Sport Sold 99 SVT T-Red Tan Interior. K&N, Magnecors, 19' Theorys, And some audio stuff.
0
gauges run about $40-60 depending on who makes them and the type of gauge.
ask hector with the red supercharged zetec with the flat black 11 Lbs. rims he has gauges in his ride.
-2000 csvt silver frost #1619 -magnaflow 14415 -optimized T/B & y-pipe -superchips xgt1 -75mm proflow maf -K&N RU-3530 -fsvt smart pump # 354Z-9H307-BC -spec stage one, LSD -low-tek,a/f,oil press.,volts -B&M short shifter -17" konig gt-r
electrical are typically easier to install, but not as accurate as mechical. Also, as has been rehashed earlier for the Duratecs, the only place ot mount an electrical sending unit for oil pressure is the rear head, its not the most accurate place to mount one.
Ryan Trollin!
There's a plug on the driver's side of the engine that you can remove and tap into.
There should be someone out there that's done it recently. I did mine a couple years back and no longer have the Mystique.
HTH
John
John what's up?!
