#1082054 10/19/04 02:35 PM
I have a Check Engine Light on, and the code came back P1120 which is Throttle Position Sensor A Out Of Range Low (Ratch too low). I had this code before and replaced the TPS hoping to get rid of it. Any ideas on what else it might be? Also, my idle is very screwy, sometimes it idles perfect, sometimes it will hang then drop to normal, others it will just hang. Any ideas would be much appreciated.
Thanks,
Mark
1998 T-Red SVT Contour #2588 of 6535 2005 F-150
#1082055 10/19/04 05:49 PM
You may have a wiring harness problem... is the insulation coming apart?
#1082056 10/19/04 06:20 PM
Idle Air Control? Don't know why you'd get a TPS code though.
#1082057 10/19/04 07:05 PM
I haven't had a chance to check the wires under the UIM yet, but I'll post when I do.
#1082058 10/20/04 03:55 AM
I checked out the wire for the TPS and it looked fine. I also noticed that it idled perfectly if the TPS was unhooked, so I guess that rules out the IAC. I got a P0122 code when I left the TPS unhooked. Any other thoughts on this one?
#1082059 10/21/04 03:31 AM
bump
#1082060 10/21/04 03:36 AM
the tps doesn't just drop onto the throttle body
the tps has a preload, best way I can put it, so if it wasn't installed right it would throw the output voltage off
