Yes there is a recall 01B78 for the dash warp for all the Tour/Mystque 1999-2000. This situation is more common in hot climate. You can give me your VIN and i will check in the oasis system from ford to see if this has already be done or not. Or you can go to your nearest Ford dealer and ask them.
Nic.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
