Clifton Offline OP
i was lookin at some post of the 3.0l in svts and i was wondering if anyone has ever squished a 3.9l v8 from the sho in there.. would be crazy fit and crazy fast
1997 BMW 318i..
1999 SVT Contour
T-Red Tan-Int
#172
born on 10/08/98
rip on 11/1/01
Chances are it would be barely faster than a stock CSVT or a CSVT w/ mild mods. If you want a fast contour, apply forced induction.
Darin P
93 Probe GT
About as close to 300hp as my Tranny can handle...
I
I
Where do these guys come from? V8?? Why? mad
99 Range Rover 4.6 HSE
Mystery Car??????
W
W
3.4L not 3.9L...
the problem is fitting it between the frame rails... hmm can anyone say widebody SVT?
-Mark
You can do something for Love...
You can do something for Money...
But there is nothing quite so satisfying as doing something out of Spite.
GTExtreme1@aol.com
Originally posted by Icey Mike:
V8?? Why? mad
Why not? laugh
Seriously, a V8 SVT would be cool, but the weight the V8 has over the V6 ruins the extra power it produces.
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
The SHO Taurus is 3.4L not 3.9L.
It is basically a 2.5 V6 with two extra cylinders. It uses the same 60 degree V as the V6 instead of the more normal 90 degree of most V8s. They had to add a balance shaft to smooth out the vibrations caused by the unnatural 60 degree V.
Do you have room to put the SHO V8 in a Contour? Maybe, if you put the two extra cylinders in the trunk. It might be easier to do a 3.0L conversion with a stroker kit to come up with 3.4L. At least that would fit.
Jim Johnson
98 SVT
if anything the 3.2L v6 would be a better idea of an engine to use...that would've been a good place to start...
1995 Probe GT ATX TOO MANY MODS
1999 Cougar V6 MTX
Stage 1: (Basic Mods)B&M STS, Bassani Exhaust, KKM intake w/ weapon R pipe, ProFlow 75mm MAF w/optimiser, YoDude Y-pipe w/hi flow cat, SVT TB, SVT Upper IM, OMP FSTB,AF gauge, Aerogear fiberglass hood (completed)
Stage 2: (Top End Work) 19-24lb injectors, P&P heads w larger valves and HPC coated, P&P and port matched lower intake manifold also HPC coated, custom ground cams, Ford Racing 9mm wires, Bosch +4 plugs, Custom burned PAC or Diablo chip (will dyno with both), Apexi SAFC (In Progress)
Stage 3: (Transmission) Quaife LSD, CM stage 3 Clutch, Fidanza flywheel (In progress)
Stage 4: (Suspension)Koni adjustibles, H&R springs, Progress 21mm rear anti sway bar (Installing on Tues)
Current dyno: 172.9 whp with just bolt ons and stock exhaust manifolds (not gutted), oh, and bad wires smile...
Lee Offline
The 3.9 Liter Lincoln LS V8 will bolt up to a MTX-75...
Lee Cox
In life begins responsability...
Project Car
Also the V8 sho was the slowest one, the 3.2L 6 would be a better choice.
**Spelling should not count**
2000 SE Zetec ATX
Medium Steel Blue (Now with large custom dent on the rear door)
Cool Blue Lows, Silver Star Highs (great lights)
"If what I said was wrong, it wasn't. I just forgot to add the rest of my post."
The v8 sho always gets the "Its the slow one" from everyone... however it makes a flatter torque curve, more hp, more torque then the 3.2 AND freaks people out when they find out the Taurus comes with a v8 .
Just remember the v8 sho atx has it all over the v6 atx. The v6 mtx is the fastest simply b/c of the manual option. 3.4 yamaha/duratec would be all over the 3.0 yamaha if the v8 came with a 5 or 6 speed. And if you want to go for a top speed run, you better believe I'm grabbing the v8 Yamaha/Duratec before I grab the suped up vulcan v6.
14.6 out of a 12 valve 3.0 Taurus
A wise man once said, rather then watch a girl wrestle I would rather see her box.
