Hi all.
I'm fairly new to my Contour, and been lurking for a while. Much kudos to you guys for the know-how and giving me the confidence to try some things myself.
Decided to bite the bullet and clean the UIM. I've done searches, but I still have three questions:
1. Read a lot of pros/cons re cleaning the UIM in place. If I'm doing plugs, wires, PCV, throttle body cleaning, etc, it's been suggested its just as easy to take off the UIM and clean it manually.
Any thoughts?
2. Question about removal. Specifically I've read lots of posts, but I'm unclear if it's water cooled (one set of instructions said to 'drain the coolant'...?)
I'm hoping that's wrong, and it's not water-cooled. (Last engine I worked on was a BMC (Triumph 1500), with twin SU carbs, never worked with injection engines. I've never heard of a cooled manifold before.)
3. Finally, what should I clean it
with ? I have thick wire, brushes, etc but no cleaner. For in place cleaning, I can't find Berrymans B-12 locally. What else should I use?
And, if I'm cleaning the UIM off the engine, what's the best thing to use? (One post said a power washer??)
Thanks all.
