Page 2 of 2 1 2
#1079304 10/16/04 06:09 AM
CEG road warrior
CEG road warrior
Originally posted by Kremithefrog:
Originally posted by LoCoZs/c:
I could get to mine from the top (right under intake manifold) and from the bottom (with the car on ramps).
Yeah 98+ and like I said, fatty! Plz don't hurt me next time u see me, u'r bigger than me, oops i already said u'r big, oo crap diggin hole... uh oh. Ima get the beat down on me.
LOL.....you don't look like you weigh much more than Eric!
#1079305 10/20/04 03:35 PM
hey! im a fat bastard and i can crawl under the car and change the filter from under neath the car. no problem.
95 Merc Stique Zetec 2.0 Auto
#1079306 10/20/04 05:15 PM
I usually put the car on ramps, and crawl underneath, on my back, with my head toward the back of the car, and my feet sticking out from under the front bumper. Then, I bend my right arm at the elbow, and extend the lower half of my arm upward, behind the tie rod. Then, leaving the lower half of my arm stationary, I bend the upper part of my arm 45 degrees toward the driver's side of the car, until it extends just behind the stabilizer, and then bend it again 30 degrees to the north, just above the lower control arm, and then bend it 45 degrees upward toward the filter, and then extend the end of my arm 60 degrees toward the front so that I can grasp the filter. Then, when the filter is loosened, I pour hot oil down my arm, across each of the five joints in my arm, until the oil accumulates in my arm pit. If the oil is very hot, I jump in pain, and slam my head into the subframe, and knock myself unconscious, and then about 20 minutes later I start all over again, this time using the left arm.
It is simpler, but not quicker, to remove the right tire.
#1079307 10/20/04 08:44 PM
9
That was funny
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
#1079308 10/21/04 12:58 AM
2000 Black CSVT MagnaFlow resonator, SHO/K&N cold air intake
#1079309 10/21/04 12:10 PM
-Ken V. 1998.5 SE Praire Tan Zetec ATX psycho_bass@hotmail.com Roush springs Roush rear sway bar BAT struts 17" Millie Miglia HT3 and a ton of subtle asthetic mods
#1079310 10/21/04 03:57 PM
They just don't build cars to be worked on by Shade Tree Mechanics anymore.
#1079311 10/22/04 02:16 PM
That's for sure. I replaced the alternator last weekend, and that task had me thinking all kind of bad thoughts about Ford engineers. On the other hand, if the alternator holds up for ten years and 140K miles, I shouldn't complain.
Page 2 of 2 1 2
