Posts: 9,602 |
You can make a scoop that attaches to where the left radiator air deflector goes/is. I cut the deflector apart, grafted a scoop onto it, and reinstalled it. I attached a hose to the back and routed it up to the air filter area. It dumps angled across the length of the filter. Also the airflow pushes back any heat seep from the other side of the heat shield.
It makes a very nice forced, fresh air source to the filter area. When moving my IAT is always at ambient temperature.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 2,097 |
I haven't decided on my intercooler for the new set-up...got in on the GB of diamond pistons...thanks to Chris and Keith...they're the best, I have my 3L apart, and everything looks great...I think i decided on my new turbo we'll see...
98 E0 SVT with some stuff
Posts: 1,859 |
Originally posted by Stazi: I'm gonna rebuild my engine in late winter.
I have low CR Diamond pistons that I'm putting in. I'll also mildly port (clean-up) the heads and fit the larger 3L valves.
Obviously I will be upp'ing to 42# injectors, an INTERCOOLER, and a GT28RLS.
Bout time. Have you figured out an intercooler yet? Someone that lives by you has a setup that will work for you.
About intercoolers, I think an air/air is better for our apps anyways, we don't run drag race cars, but you have to live with what works. Getting a fmic to fit aside, I wonder if modifiing the air dam would work to get air flow to the rad, or maybe pipe some air in?
'99 Silver svt
For sale
19" Axis Neo wheels
3.0 parts, pre-98 trunk,
Check classifieds
bp.powell@comcast.net
Posts: 1,238 |
What about twin sidemounts? Kinda like the 300Z? I dont know just throwing out ideas. -tropictour
2000 Contour SVT
Tropic Green
SHO Shop CAI
Bassani
1999 Contour SE
BAT Kit
Posts: 10,015 |
Even more ludicrous, as geting two sets of pipes to the front is even more of a headache and it'll have lag and pressure drops like a MOFO.
I might look into buying Bronco's Water IC.
I have an FMIC in a box, and am toying with losing the A/C.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Learned patience the hard way
Posts: 2,454 |
Only way of getting an FMIC to fit under the front bumper would be to hack out the entire area where the lower grill is and then throw a restriction in front of the radiator and A/C condenser as well. It really just isn't practical with the piping and space on our cars to even consider it.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Posts: 3,840 |
Originally posted by Buckshot77: It really just isn't practical ...
Yeah, that may be true. But is it practical to have 396 whp in a front drive Contour?
-SAV
Troll. 1997 VW Jetta MkIII GLS 5spd
All hail my appearance on CEG!
Posts: 6,760 |
For road racing yes... Originally posted by SAV: Originally posted by Buckshot77: It really just isn't practical ...
-SAV
Ryan
Trollin!
Posts: 2,454 |
By practical I meant in the way of it is most likely going to be less efficient than a properly sized water to air unit, take more time and effort to make work, hack the crap out of your car, and most likely cost the same or more by the time you get done fabbing everything.
In regards to 396 being practical, it is useful on a road course when I can keep up with and slowly chase down 03/04 cobras in the top end and outrun most other things on the track in the straights. I'm hoping to post a better number this spring once I get the car tuned and a few other goodies reworked on the intake side of things.
Rick
Buckshot77@msn.com
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by Buckshot77: By practical I meant in the way of it is most likely going to be less efficient than a properly sized water to air unit, take more time and effort to make work, hack the crap out of your car, and most likely cost the same or more by the time you get done fabbing everything.
Rick
Can't wait to see...make sure to post some vids.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
