Posts: 10,015 |
I'm gonna rebuild my engine in late winter.
I have low CR Diamond pistons that I'm putting in. I'll also mildly port (clean-up) the heads and fit the larger 3L valves.
Obviously I will be upp'ing to 42# injectors, an INTERCOOLER, and a GT28RLS.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 718 |
I CAN'T WAIT TIL I GET OUT OF SCHOOL!!!
(sorry for yelling) lol
1999 Cougar V6 MTX
SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
Posts: 3,840 |
One of you turbo gods HAS to figure out a FMIC. I think it would look deadly on one of our cars. I know it's been said that it isn't possible, but that right there would be the motivation to make the impossible happen.  -SAV
Troll. 1997 VW Jetta MkIII GLS 5spd
All hail my appearance on CEG!
Posts: 9,602 |
Originally posted by SAV: One of you turbo gods HAS to figure out a FMIC. I think it would look deadly on one of our cars. I know it's been said that it isn't possible, but that right there would be the motivation to make the impossible happen.
-SAV
Who cares about looks over function. Oh nevermind there is a whole crowd about that.
A FMIC would choke off the airflow to the radiator and you would have to lose the A/C system as well. Neither of which I would recommend nor would myself even remotely consider.
Well actually I did consider it remotely but came to the same conclusion over and over hence this information.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,196 |
I've got no A/C in my Turbo tour, unfortunately I'm done putting money into it so I'll let the next owner figure out a FMIC.
2004 Evolution VIII cams-exhaust-tune
315whp 12.7@109
Posts: 3,840 |
Originally posted by DemonSVT: Well actually I did consider it remotely but came to the same conclusion over and over hence this information.
I knew you'd come out truthfully sooner or later.
-SAV
Posts: 9,602 |
Originally posted by SAV: I knew you'd come out truthfully sooner or later.
You want to know the worst part about it. It was for a supercharger setup idea I had once... Shhhh... Don't tell anyone I used the S/C word...
2000 SVT #674
Posts: 3,840 |
LMAO! Your secret is safe with me.
Posts: 2,676 |
I think it would ONLY work, after spending a weekend under the car, if we extended the bumper farther out (j/k!). . .but like Demon said, it would completley choke off the radiator, and you NEED ALL OF THE AIR you can get to cool anything this powerful and hot off. . . .
On a more ricey note, I like the "heat exchanger that looks like a mini FMIC" look on my car, I'll take a pic and post if no one knows what I'm talking about. . .
And on a more functional horsepower note, Demon you think it would be a worthwhile upgrade to remove my driver's side fog light and add a air scoop directed towards the 7" K&N? Should I use a larger air filter to squeeze out a little more? What was that calculation for size of filter and cfm?
Posts: 431 |
ssmumich00 I think with the power you have you should try to get it to the ground. I know you have no grip 1st through 3rd with that much power. I run 13 psi and spin tires all through third even on top third. Have you ran your car at the track yet. I think the intercooler you have is well suffice because I am still using the smaller core running 13 psi with no pinging or heat problems. The intercooler he has is definitly better than an Air to Air. I am adding Water injection to mine tomorrow and going try to push 15 psi through it watching My EGT like a hawk.
99 SVT #198 blk/blue
Spec 3/quaife/stage 2 shafts
T3/T4 fully built 3.0
ported heads
water injec./intercooled
13.2 @ 107 mph
clifford alarm and turbo timer
koni struts H&R springs
intercooler for sale
