Posts: 7,025 |
Originally posted by todras: That's not a Contour.
Slap a T-66 on a contour, and youll get the same result.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 9,602 |
Originally posted by beyondloadedSE: why not? Harolds turbo Maxima puts down high 400 wheel hp on his stock motor with pump gas.
He's been through quite a few engines though.
Like I said someone is bound to do it to the Duratec sooner or later and find it's limits.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 7,025 |
yes, hes been through quite a few engines. (6 iirc) Mostly because of his own insanity though lol. I mean, who runs 15 psi and 150 shot on nitrous without any tune at all? That motor lasted 18 hours after installing it. He just replaced the motor he had a couple weeks ago with a used one because the waterpump was bad LMAO!  Apparentely, its easier to just install a new engine than to install a new waterpump according to him. This new stock motor with about 11.9:1 air/fuel tune has already seen 23 psi with a T-66 and its still holding together nicely. Im sure those Nissan motors are built better no doubt.
btw, last weekend he ran a new best of 11.9 @ 125!
Jim Hahn
Posts: 21,197 |
 FWD too.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 10,015 |
Originally posted by beyondloadedSE: yes, hes been through quite a few engines. (6 iirc) Mostly because of his own insanity though lol. I mean, who runs 15 psi and 150 shot on nitrous without any tune at all? That motor lasted 18 hours after installing it. He just replaced the motor he had a couple weeks ago with a used one because the waterpump was bad LMAO! Apparentely, its easier to just install a new engine than to install a new waterpump according to him. This new stock motor with about 11.9:1 air/fuel tune has already seen 23 psi with a T-66 and its still holding together nicely. Im sure those Nissan motors are built better no doubt.
Jesus that's a fast Maxima!
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 5,810 |
Originally posted by SAV-ZX2: Originally posted by DemonSVT: Originally posted by SAV-ZX2: Definitely.
You don't get 400 horsepower by just a simple turbocharger.
That all depends.
Certainly just bolting on a turbo can give 400 HP. That's an easy given.
However if the stock pistons & rods can handle it is another question altogether now. "To date" we know 330ish is safe with a good tune. Eventually we'll know their "true" safe limits.
Still 330 wheels from a small V6 is impressive for OEM parts designed for general NA applications.
Ok ok Master Demon.
You don't get 400 horsepower for very long by way of just a turbocharger.
I'll agree though. 330 at the wheels is damn impressive for a V6.
Why not? Mine has been doing it for going on 10 months now on pump gas. I take that back, I detuned it to 315 wheels when I left.  330 wheels is pretty close to 400 HP at the crank. I'm very confident that with pump gas it will run 350 wheels all day long. The part that you can be concerned with for the stopckl pistons is that they can sustain 330 Ft-lbs of torque on pump gas!!! The rods can handle higher rpms, at least 8K. The turbo motor can actually reduce some of the stress of high-torque tensile loads that will break a rod if it were in a NA motor with the same load. Will the pistons handle 400 wHP on pump gas and high rpm??? I don't know but I'm guessing it doesn't take 330 ft-lbs at 7000 rpm to make 400 wHP. IT is definitely possible.
See My Mods
Posts: 3,840 |
[sigh] I just need to shut up.
Troll. 1997 VW Jetta MkIII GLS 5spd
All hail my appearance on CEG!
Posts: 333 |
hey man, thats awsome, but you droped your torque (like it matters)
Posts: 7,025 |
Originally posted by Augi: hey man, thats awsome, but you droped your torque (like it matters)
umm...doesnt every dyno graph.
Jim Hahn
Posts: 718 |
Originally posted by beyondloadedSE: Originally posted by Augi: hey man, thats awsome, but you droped your torque (like it matters)
genius
1999 Cougar V6 MTX
SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
