Page 9 of 13 1 2 7 8 9 10 11 12 13
#1079246 11/11/04 05:41 PM
Originally posted by todras:
That's not a Contour.
Slap a T-66 on a contour, and youll get the same result.
#1079247 11/11/04 05:49 PM
Originally posted by beyondloadedSE:
why not? Harolds turbo Maxima puts down high 400 wheel hp on his stock motor with pump gas.
He's been through quite a few engines though.
Like I said someone is bound to do it to the Duratec sooner or later and find it's limits.
#1079248 11/11/04 05:55 PM
yes, hes been through quite a few engines. (6 iirc) Mostly because of his own insanity though lol. I mean, who runs 15 psi and 150 shot on nitrous without any tune at all? That motor lasted 18 hours after installing it. He just replaced the motor he had a couple weeks ago with a used one because the waterpump was bad LMAO! Apparentely, its easier to just install a new engine than to install a new waterpump according to him. This new stock motor with about 11.9:1 air/fuel tune has already seen 23 psi with a T-66 and its still holding together nicely. Im sure those Nissan motors are built better no doubt.
btw, last weekend he ran a new best of 11.9 @ 125!
#1079249 11/11/04 09:12 PM
FWD too.
#1079250 11/12/04 02:13 PM
Jesus that's a fast Maxima!
#1079251 11/13/04 08:53 AM
W
W
Originally posted by SAV-ZX2:
Definitely.
You don't get 400 horsepower by just a simple turbocharger.
That all depends.
Certainly just bolting on a turbo can give 400 HP. That's an easy given.
However if the stock pistons & rods can handle it is another question altogether now. "To date" we know 330ish is safe with a good tune.
Eventually we'll know their "true" safe limits.
Still 330 wheels from a small V6 is impressive for OEM parts designed for general NA applications.
Ok ok Master Demon.
You don't get 400 horsepower for very long by way of just a turbocharger.
I'll agree though. 330 at the wheels is damn impressive for a V6.
Why not? Mine has been doing it for going on 10 months now on pump gas. I take that back, I detuned it to 315 wheels when I left.
330 wheels is pretty close to 400 HP at the crank. I'm very confident that with pump gas it will run 350 wheels all day long.
The part that you can be concerned with for the stopckl pistons is that they can sustain 330 Ft-lbs of torque on pump gas!!!
The rods can handle higher rpms, at least 8K. The turbo motor can actually reduce some of the stress of high-torque tensile loads that will break a rod if it were in a NA motor with the same load.
Will the pistons handle 400 wHP on pump gas and high rpm??? I don't know but I'm guessing it doesn't take 330 ft-lbs at 7000 rpm to make 400 wHP. IT is definitely possible.
#1079252 11/13/04 02:54 PM
SAV Offline
[sigh]
I just need to shut up.
Troll. 1997 VW Jetta MkIII GLS 5spd All hail my appearance on CEG!
#1079253 12/26/04 09:19 AM
hey man, thats awsome, but you droped your torque (like it matters)
#1079254 12/26/04 05:37 PM
umm...doesnt every dyno graph.
#1079255 12/27/04 12:29 AM
9
genius
1999 Cougar V6 MTX SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
Moderated by  mbb41_dup1
