Posts: 2,676 |
Originally posted by SalKhan: Quick question:
Any reason you went with the CR pistons you did and not lower? I haven't been following so I'm not sure if I missed something or not.
Well, ideally the 9:1 was supposed to be low enough to run high boost but not so low that I'd loose significant "around the town" power, so to speak. But, in reality, what ADC found was that because I had turbo spec heads done and a little more was taken out, my compression was actually more like 8.5:1, not exactly 9:1. . .but I think it's an ideal number, whatever my real CR really is (somewhere inbetween 8.5 to 9:1), since I don't have much lag at all, there's a reduced risk of detonation, and I still retain much of the around the town zip my 10:1 CR previously gave. . .
Posts: 10,015 |
Originally posted by warmonger: Oh BTW, can you tell me or email me a picture of that engine brace you have that eliminated wheel hop? Also, check out the post I made in the 3L forum under "Big Dogs" or whatever it is called.
tom
http://groups.msn.com/KeyserSVT/shoebox.msnw?action=ShowPhoto&PhotoID=19
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 2,676 |
Originally posted by Stazi: Originally posted by warmonger: Oh BTW, can you tell me or email me a picture of that engine brace you have that eliminated wheel hop? Also, check out the post I made in the 3L forum under "Big Dogs" or whatever it is called.
tom
hmm, cool, there it is. . .
Posts: 1,055 |
Originally posted by Ray: On an off note, maybe you could comment on those S03's? I am purchasing a set of 4 Pole Positions in a week, and I wanted some "real world" experience with them.. Some reviews say that they are TERRIBLE when compared to the S02 PP, and a few tire guys are telling me the exact opposite..
Maybe you could explain a little about their treadwear, noise, etc? (SORRY FOR THE HIJACK.... Thanks ..)
Ray
Ray didnt I sell you some s-02's?? you didnt like em? Derek
Derek Johnson
88 TurboTBird 32psi, t3/t4 bb 50trim, megasquirt, 3 bar map, 50lb inj, roller cam w adj. gear, header, 3" downpipe and full exhaust, gutted intake manifolds, spec stg 3
95SE 3L gone
Posts: 7,100 |
Actually, Derek, I LOVED THEM..
They are stickier than I thought any tire could be, and wore quite evenly. The tire noise was "desirable", though not quiet. Treadwear was on the VERY low end, but that is a given when you want sticky tires.
I wanted to get another set of S02 PP's, but they are discontinued, and I couldn't find another set. I was going to "settle" for the S03 PP's (I say "settle", when I don't even know for sure how well they work..), but wanted someone to back up either end of the spectrum that I had heard. Some reviews online stated they weren't as good as their predecessors, and a few people seemed to love them, ranking them far above the S02's..
Just curious was all..
Ray
'99 CSVT - Silver #222/276
Posts: 208 |
wow! now get that sucker to the track and put down some killer numbers!
00 SVT Contour: SHM LT headers, LSD, Spec Stg 3...dyno:190.3whp sold 02/04
04 Subaru Baja Turbo 5-spd
00 Camaro SS 393cid: 510rwhp/469rwtq, 11.16 @ 124.95(hit 1-2 limiter)
www.erikz.org
Posts: 7,025 |
Pretty much I explained to them that it failed on the dyno on a 4th gear pull making only 220 whp. It only had about 350 miles on it of soft driven miles. Anyways, even though I had more axles for more than 6 months (over year exactly) to fall under warranty, they still said send it back and they fixed it free of charge. Im not sure what was different the second time around because they sent back the same axle, but it fit perfectly. Maybe it was because they fixed the tripod.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 2,676 |
PICS OF TURBO, ETC. I called DSS up yesterday, got an RMA number, they seem pretty cool about it, I probably won't replace the axle until I bust the stock one that's on. . . I'm not very happy with all of the problems we're having, these things SUCK. . .hell, the stock passenger side axle could take the 401fwhp. . .WTF?
Posts: 1,859 |
Originally posted by ssmumich00: I'm not very happy with all of the problems we're having, these things SUCK. . .hell, the stock passenger side axle could take the 401fwhp. . .WTF?
But who knows for how long. You don't want to get stranded some were because you broke an axle. At least DSS is cool about fixing them. Hopefully everybody that orders one doesn't have to send one back though.
'99 Silver svt
For sale
19" Axis Neo wheels
3.0 parts, pre-98 trunk,
Check classifieds
bp.powell@comcast.net
Posts: 7,117 |
tom
If I got my bearings right from looking at that picture, the mount will allow a little F-R movement, but nearly all of the rotational movement is eliminated?
