Page 2 of 3 1 2 3
#107733 10/21/01 04:00 PM
how hard is it to install a y-pipe anyway?
Tom
1998.5 T-Red SVT Contour
#6044 of 6535
K&N (Thanks Paul)
tcomps@att.net
Aim: Paintball4life69
*Looking to sell svt to get mustang*
#107734 10/21/01 04:16 PM
Not a problem IF you can get the bolts off. I had to make a trip to the muffler shop to get them loosened. If you're gonna do it yourself, have a local shop close by and open just in case.
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
#107735 10/21/01 06:55 PM
Originally posted by I-Dom-In-8:
Hey man that would be awsome if you can. And thanks for the pics they will also help me out a lot. Kajork20@yahoo.com.. thanks again
Drawing sent, I hope it is of some use.
paul.
5 Dr, 2.5 V6 Ghia X, 1999
Modifications:-
Inventor of the inductive Secondary monitor
Chrome grill
JR cone air filter
Black Diamond cross-drilled & grooved discs with Predator pads,
ST200 throttle body, upper and lower extrude-honed intake manifolds
Scorpion s/steel exhaust
Current Project.. Building a ST200 powered MKI
paullorman@btopenworld.com
#107736 10/21/01 07:19 PM
9
9
Has anyone up here in canada ordered the y-pipe from the sho shop and how much did it cost to get it up here in canadian $$$?
96 SE V-6 MTX
SVT E1 rims,205/55/16 Comp TA VR 4's,custom exhaust,KKM filter,bullit fuel door
painted calipers,trans cocktail mix,tinted windows/body coloured grill/engine cover/SVT door sills
#107737 10/21/01 07:41 PM
Derk2000 your correct on the 12hp 6tq. Could feel it once I put her on(and reset the puter). Great difference!!!!! All the way through the graph!!!!
Merlin
281hp 324tq
Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
#107738 10/21/01 10:56 PM
I
I
paul.
Thank you so much man now i can still get my Y-pipe laugh .
#107739 10/22/01 12:49 PM
I
I
Merlin was that 12/6 with just the catless y pipe or did you change anything else? I think Im going to do this mod. It sounds like it give a lot for the money. How much longer will the stainless last compared to the aluminum?
98 svt #3967/6535
BOD 10/13/97
itg air filter
air inlet pipe
south country strut tower brace
A pillar gauge pod w/autometer Volts, Oil Pressure. and A/F Ratio
Replaced resonator w/Dynomax Bullet
#107740 10/23/01 12:32 AM
VERY pricey once all the duties, brokerage, gst, etc. added in. It was close to $800 Cdn when all was said and done with the exchange rate. If I knew it was gonna be that expensive I would have had a local muffler shop make one. It was the stainless steel version I bought btw.
#107741 10/23/01 12:34 AM
Is it against the law to get someone to buy it for you and have them ship it to you like its a gift?
Cause thats what I would be doin? laugh
That sucks!! You guys must make alot of cash up there! wink
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
#107742 10/23/01 10:56 PM
it took me 45 min to install the pipe. i had access to airtools, though. helped a ton. I'd probably recommend getting it welded together, though.
2000 Silver SVT #1602
Check it out in the registry!
Mi Coche
Page 2 of 3 1 2 3
