Posts: 269 |
how hard is it to install a y-pipe anyway?
Tom
1998.5 T-Red SVT Contour #6044 of 6535 K&N (Thanks Paul) tcomps@att.net Aim: Paintball4life69 *Looking to sell svt to get mustang*
Posts: 407 |
Not a problem IF you can get the bolts off. I had to make a trip to the muffler shop to get them loosened. If you're gonna do it yourself, have a local shop close by and open just in case.
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
Posts: 306 |
Originally posted by I-Dom-In-8: Hey man that would be awsome if you can. And thanks for the pics they will also help me out a lot. Kajork20@yahoo.com.. thanks again Drawing sent, I hope it is of some use. paul.
Posts: 117 |
Has anyone up here in canada ordered the y-pipe from the sho shop and how much did it cost to get it up here in canadian $$$?
96 SE V-6 MTX SVT E1 rims,205/55/16 Comp TA VR 4's,custom exhaust,KKM filter,bullit fuel door painted calipers,trans cocktail mix,tinted windows/body coloured grill/engine cover/SVT door sills
Posts: 2,631 |
Derk2000 your correct on the 12hp 6tq. Could feel it once I put her on(and reset the puter). Great difference!!!!! All the way through the graph!!!!
Merlin
281hp 324tq Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
Posts: 3,421 |
paul. Thank you so much man now i can still get my Y-pipe  .
Posts: 30 |
Merlin was that 12/6 with just the catless y pipe or did you change anything else? I think Im going to do this mod. It sounds like it give a lot for the money. How much longer will the stainless last compared to the aluminum?
98 svt #3967/6535 BOD 10/13/97 itg air filter air inlet pipe south country strut tower brace A pillar gauge pod w/autometer Volts, Oil Pressure. and A/F Ratio Replaced resonator w/Dynomax Bullet
Posts: 407 |
Originally posted by 96 contour seguy: Has anyone up here in canada ordered the y-pipe from the sho shop and how much did it cost to get it up here in canadian $$$? VERY pricey once all the duties, brokerage, gst, etc. added in. It was close to $800 Cdn when all was said and done with the exchange rate. If I knew it was gonna be that expensive I would have had a local muffler shop make one. It was the stainless steel version I bought btw.
Posts: 2,066 |
Is it against the law to get someone to buy it for you and have them ship it to you like its a gift? Cause thats what I would be doin?  That sucks!! You guys must make alot of cash up there!
Posts: 1,812 |
it took me 45 min to install the pipe. i had access to airtools, though. helped a ton. I'd probably recommend getting it welded together, though.
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
